Hi there,
I´m a rookie on arduino and programing it, but i do have some experience in networking and electronics and programming in other (simplier) languages...
Well, what Im trying to make is a remote panic button that triggers an alarm siren, the problem is that the siren is half a mile away and passing some cable is not an option. So, i currently have a Wireless ethernet link to that place so on the network side im covered, but not on the button.
My idea is to use 2 Arduinos UNO with Ethernet Shields, and when i press a button on "Client" side it sends a GET command to the second arduino who will performing as a server and this triggers a relay on... and when i want it to shut down, press the button 5 seconds to do that. Here's the schematics.
CLIENT SIDE:
SERVER SIDE:
Right now i have the server side running but i have a week trying to figure it out how to do the client and honestly don't have any ideas left.. i feel stuck.
Here is the server side code, its not mine i just changes some values the credits are from Rui Santos. at
@Random Nerd Tutorials
heres the code. Im planning to use the server on 192.168.88.250 and the client on 192.168.88.251 on the same subnet and physical network segment.
#include <SPI.h>
#include <Ethernet.h>//Establecer los datos de IP
byte mac[] = {
0x00, 0x02, 0x6F, 0x00, 0x00, 0x01 };
IPAddress ip(192,168,88,250);
IPAddress netmask(255,255,255,0);
IPAddress gateway(192,168,88,254);// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);// Relay state and pin
String relay1State = "Off";
const int relay = 7;// Client variables
char linebuf[80];
int charcount=0;void setup() {
// Relay module prepared
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);// Open serial communication at a baud rate of 9600
Serial.begin(9600);// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
}// Display dashboard page with on/off button for relay
// It also print Temperature in C and F
void dashboardPage(EthernetClient &client) {
client.println("");
client.println("<meta name="viewport" content="width=device-width, initial-scale=1" <link href="https://fonts.googleapis.com/css?family=Montserrat\" rel="stylesheet"> body { font-family: 'Montserrat', serif; font-size: 15px;}");
client.println("Relay module control. - <a href="/">Refrescar
// Generates buttons to control the relay
client.println("Relay 1 - Estado: " + relay1State + "
// If relay is off, it shows the button to turn the output on
if(relay1State == "Off"){
client.println("<a href="/relay1on">ON");
// If relay is on, it shows the button to turn the output off
else if(relay1State == "On"){
client.println("<a href="/relay1off">OFF");
client.println("");
}void loop() {
// listen for incoming clients
if (client) {
Serial.println("new client");
memset(linebuf,0,sizeof(linebuf));
charcount=0;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
linebuf[charcount]=c;
if (charcount<sizeof(linebuf)-1) charcount++;
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
dashboardPage(client);
if (c == '\n') {
if (strstr(linebuf,"GET /relay1off") > 0){
else if (strstr(linebuf,"GET /relay1on") > 0){
digitalWrite(relay, LOW);
relay1State = "On";
// you're starting a new line
charcount=0;
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
Thank you so much for advance.
JB
