Hi all,
Since two days I'm trying to debug my Mega 2560 R3. I'm a beginner, but I read a lot of forum.
At first, I have to say that for an unknown reason, I fried the voltage regulator. I change it, now the ON light is lit.
Also the computer recognize the arduino in the device manager.
After the fix, the L led wasn't blinking anymore, so I used one of my Uno to reload the bootloader and the L led flashed again
Now I try to load a sketch and I see that the TX or RX led still off.
- I tried to load sketch using my Uno on pin TX0, RX0, +5, gnd, reset, no luck
- I tried to load sketch using my Uno on 2560 (pin 10 to 13 of Uno on 50 to 53 of the Mega), no luck
- I tried to reload the firmware in the Atmega16U2, but I'm not able to put in DFU (short the 2 pins on USB ICSP doesn't change nothing)
So I'm not sure how to know if I fried something else.
Do the computer will recognize the mega if the Atmega16U2 is burned?
Is it possible to load sketch in the Mega using a Uno? (maybe I did something bad in my other test)
Thanks
Etienne
