Hello Guys ;
I'm trying to write a code to do the following:
When I press switch 1 , the Loop will ignore switch 2 and Vice Versa. I use for this an infinite loop "while(1)" and It's working great , the problem is ofc I can't call functions from outside the while(1) loop so if I want to display for example I must write Serial.println("switch1 on"); inside the infinite loop !
So how can I replace the while so I can call functions in order to add more actions when the switch is HIGH.
int switch1 = 37;
int switch2 = 38;
int led1 = 34;
int led2 = 35;
enum disVar
serial,
serial1,
serial2
byte disVar = serial;
pinMode(switch1, INPUT);
pinMode(switch2, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
DisplayDataLCD();
checkswitch1();
checkswitch2();
delay(250);
void checkswitch1()
while (1)
if (digitalRead(switch1) == HIGH)
disVar = serial1;
digitalWrite(led1, HIGH);
} else
disVar = serial;
void checkswitch2()
while (1)
if (digitalRead(switch2) == HIGH)
disVar = serial2;
digitalWrite(led2, HIGH);
} else
disVar = serial;
void DisplayDataLCD()
switch (disVar)
case serial1 :
case serial2 :
Serial.println("switch2 on");
case serial:
Serial.println("greetings");
Thx )))))
