Click to start debug
IDE version 2.2.1
Mac Mini I7
Mojave
Removed IDE and ALL libraries, folders, caches, configurations, etc.
Reinstalled - same error.
Upgraded to Sanoma 14.2.1
Hi @beananimal. Do you have a CMSIS-DAP-compliant debug probe connected between your computer and the SWD test pads on the bottom of the Nano 33 BLE board?
Hi - Yes I have an Atmel-ICE and have tried another older Segger EDU.
Maybe I am doing something wrong, but the lack of information is frustrating. I posted again today in frustration, but have honestly moved on. I have two BLE boards, the 110wifi and a few mega boards. Things were working find ~6 months ago. I updated the IDE and now nothing works. I can compile and flash, but don't even get serial comms most of the time. The IDE constantly hangs (indexing). I thought it was this Mac so went ahead and fully cleared IDE and Cache, etc. Upgraded to Sanoma and it is no better. I can't consistently get a serial print "hello world" to show up, let alone debug. Often the IDE loses track of boards, etc.
I moved over to my MacBook Pro and have exactly the same issues on Monterey where I made the mistake of updating to latest version of IDE (weeks ago before i knew I was going to have problems).
So - as I stated, I posted out of frustration and have no more time to devote to this. The IDE does not feel well supported anymore and is riddled with bugs. I will circle back one day when I have time.
Thank you for responding, but consider this closed.
If you want to try using the debugger with the Nano BLE 33, I suggest trying the latest nightly build of Arduino IDE. A lot of work has been done recently on the debugging framework. The nightly build download links are listed here:
The release version of the IDE can be installed at the same time as the nightly so you can give the nightly a try and then switch back to the release version later if you decide it doesn't provide any benefits.
Hi - Thank you for the response.
I apologize if what I what I posted was ambiguous. I have only had the BLE 33 boards for a week or two.
My IDE is what was working fine 6 months ago. But now I am having problems with just about everything. Ignoring, the debugger, I can't get the Nano BLE 33 to behave consistently and the IDE is kind of flaky. Serial problems, forever indexing, buttons not working sometimes, etc. As I said, this is on two machines and two different MacOS generations. I ran out of patience playing with it and have removed the materials from my desk to focus on other things. If anything I will try to go back to a build from last year where things worked for my purposes.
