Hello I've dug out an old lcd breakout kit I got back in high school
(don't know what the hell I was thinking)
any how I have pulled up all the info I can find on this product and I
don't even know where to start with the wiring mainly because the
data sheet is a little intimidating.
This is the following links I have found related to it
Built-in controller: Samsung KS0713 datasheet
here is the product
Schematic
Pinout
Mentioned that is has an On-board HV826MG-G to drive EL backlight
I'm running a iduino but also have a uno if I need to switch out for it
All I would like to do is just get the demo working to learn and play with it
and like I mentioned before I don't know where to even start with this
any direction would be appreciated.
potential lcd code to use if example code wont cut it?
https://bitbucket.org/bperrybap/openglcd/wiki/Home
quick edit:
I do know how to use the 4 pins for the touch screen on it.
