Reset Encoder to Zero
I’m using quadrature.h library to count pulses and revaluations. Everything is working fine except I can not figure how to reset the encoder count to 0. Attached is a simple sketch using the above library. I’ve included a few of the ways I’ve tried to reset the encoder count to 0. Thanks for any help.
#include <quadrature.h>
  Because the attachInterrupt(int, function_ptr, const) requires
    a function pointer as its final argument the encoder class
    cannot use normal construction.  Each instance of
    the Quadrature_encoder must be a singleton class constructed
    from the template with the two integer arguments of the
    interrupt pins used for the encoder.  For example to build
    a quadrature encoder to use int0 and int1 on the Arduino Uno
    you would construct it like this:
        Quadrature_encoder<0, 1> encoder;
  The following enums are provided in the header file:
    Motion::motion {frwd, back, stop}
  Board::board {uno, due}
  The constructor for a Quadrature_encoder requires a board type
  so it an configure the interrupt pins properly.  The default is
  an Arduino Uno.
  Quadrature_encoder<PIN_A, PIN_B> (Board::board b = Board::uno)
    The public methods of Quadrature_encoder are:
    begin() - must be called in setup
    count() - returns a long of the encoder count
    motion() - returns a value from the Motion::motion enum
      corresponding to what direction the shaft has turned
      since the last time motion() was called.
                reverse() - changes the polarity of the decoder in case
                        you need to change the sign of the output.  Run
                        the example below with the .reverse() line commented
                        out and see the difference in output.
    So to use the encoder you would construct an object with
    the template parameters and a board definition.  Then you would call
    encoder.begin() in the setup() of the sketch.  Then you
    can call encoder.count() or encoder.motion() anywhere else
    in the sketch to read the encoder.
    EVEN WITH ENCODER POWER OFF THE COUNT REMAINS.
Quadrature_encoder<0,1> encoder(Board::uno);
//stepper display
LiquidCrystal_I2C lcd(0x27,20,4);//stepper display
  lcd.init();
  lcd.backlight();
  lcd.begin(20,4);
  encoder.begin();
//  encoder.reverse();
  //read the encoder
  long ct = encoder.count();
  lcd.setCursor(5,0);
  lcd.clear();
  lcd.print(ct);
  lcd.print(" Encoder Count");
  //reset
//  encoder.write(0);//won't compile
//  Quadrature_encoder.write(0);//won't compile
//  inline int32_t readAndReset();//no effect
  ct = 0;
  lcd.setCursor(0,1);
  lcd.print(ct);
  //format the output for printing
  char buf[50];
  sprintf(buf, "enc1 count is: %d", ct);
  Serial.println(buf);
  //check the motion
  Motion::motion m = encoder.motion();
  Serial.println(text(m));
  //delay the loop for a moment.
  //Note that the encoder continues to count even during this
  //delay because it is interrupt driven!
 // delay(100);
Encoder_Reset_Test.ino (2.9 KB)
Please insert the code to forum as text using a code tags.
You could try to add a public method in the the library .h file under public:
Something like:
void reset() {
    noInterrupts();
    ct = 0;
    old_ct = 0;
    out_val = 0;
    interrupts();
Worked perfect!! Thank you.
olf20 / Bob
You are welcome!
