Reset help
Hi, Can anyone help me with this.
I have created a shield for the arduino uno that has a Serial LCD, Piezo Buzzer, Shiftbrite and a Xbee connnected to it. It's running off a 9V battery that I have connected an on/off switch to. The problem is that when I turn the power on, the Arduino sketch that I had previously uploaded to the board will not activate unless I physically press the reset pin on the Arduino. I don't want to have to keep pressing this when I turn it on. Does anyone have any suggestions as to why this is so and how to fix it????
Hi, can anyone help me with this.
I've created an Arduino uno shield that has a serial LCD, Piezo Buzzer, Shiftbrite and a Xbee connected to it. It is running off a 9V battery that I have connected to the Arduino. I use a switch to turn the battery on and off. The problem is this, every time I turn the power on, the sketch that I had previously programmed on the arduino won't load up unless I physically press the reset button. Is there a reason why this happens and can anyone suggest some solutions so I do not have to keep pressing the reset???
Does the Arduino have power when the shield's power switch is off?
Sure. Use a real battery. Put the 9V battery back in the smoke alarm you stole it from, and use 4 or 5 AA batteries.
Moderator edit: Threads merged. (Nick Gammon)
Please don't create two threads asking the same question. You won't get twice the amount of help. There is a "modify" button if you want to correct spelling mistakes.
Sorry about the two threads, I'm new to this. The Arduino does not have power when the switch is off! I take it to be a power issue if someone is suggesting using more batteries, but I do not wish to do this. Is there any other suggestions??
Sounds like the reset pulse is coming too fast. You need some sort of slower reset. Maybe put a 0.1 uF capacitor between the reset and Gnd pins.
That has done the trick. Thanks for all your help.
Regards,
Simon
