Hey, Snoop the noob dev here. Ive read many topics and im aware that reseting millis() is a bad option. However im trying to make a program that starts a timer when the button is pressed and reset the timer when its not pressed. Example:
Holding button*
if (time_now == 1000) {
do something
if (time_now == 2000) {
do something
if (time_now == 4000) {
do something
My code:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
unsigned long time_now = 0;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
time_now = millis();
// turn LED on:
digitalWrite(ledPin, HIGH);
} if (time_now == 2000) {
} if (time_now == 4000) {
// turn LED off:
digitalWrite(ledPin, LOW);
time_now = 0;
I want the timer to only count while button is pressed, and always start to count from 0 without using Delay.
if (millis() - lastEventAtMs >= 1000) {
// Timer expired because 1000mS has passed since last event, so do something
Thanks for the reply, i will update my code. However Millis() runs all the time, so how do i prevent it from running if the button is not pressed, and how do i "reset it" so it starts at 0 next time button is pressed?
snoopynoob:
You don't. That is a nonsensical suggestion.
You use the answer you were given.
OK, I confess, he was pulling you leg somewhat.
You were supposed to figure out the "obvious" - to "start" your timer you use:
snoopynoob:
Thanks for the reply, i will update my code. However Millis() runs all the time, so how do i prevent it from running if the button is not pressed...
millis is supposed to run all the time. What if you needed multiple timers with differing presets and unpredictable start times? Resetting millis would destroy that.
snoopynoob:
Resetting a timer is, essentially, holding its value at zero. This is done by constantly loading the time with the value of millis so the *difference between them *(millis() - yourTimer) is zero. When you stop resetting the timer the value of millis() - yourTimer begins to increase. That *difference *is what is compared to decide if time has expired.
Creating a separate yourTimerX for each interval is how multiple timers are implemented.
You can stop and restart the millis timer by disabling timer0's ISR. I do not know the syntax out of my head for that. This is perfectly safe to do if this is the only thing you want to do with millis().
Out of the box the arduino library does not allow you to reset the millis counter. You could look the source code up and add a clear function yourself. It is doable if you really really want it. It is just not recommendable as you see in earlier responses as you might break other things.
A workaround is relative easy. I believe that this code does what you want.
unsigned long yourCounter;
unsigned long lastTime;
const int intervalTime = 10; // every 10ms?
const int yourButton = 12; // fill in your button
pinMode(yourButton, INPUT_PULLUP); // pullup desirable?
unsigned long currentTime = millis();
if( currentTime - lastTime >= intervalTime ) {
lastTime = currentTime;
if( digitalRead(yourButton) == LOW ) { // if we use pullup resistor
yourCounter += ( currentTime - lastTime );
Serial.println(yourCounter);
else {
yourCounter = 0;
currentTime minus lastTime is the difference. If the button is pressed this difference will be added to your own counter and it will be printed on the serial monitor. If the button is not pressed your counter will be continously set at 0.
