[résolu] écran tactile
Bonjour,
voici le code que j'utilise (pour tester un écran sur un uno)
/*______Import Libraries_______*/
#include <SPFD5408_Adafruit_GFX.h>    // Core graphics library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPFD5408_TouchScreen.h>
/*______End of Libraries_______*/
/*______Define LCD pins (I have asigned the default values)_______*/
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
/*_______End of defanitions______*/
/*______Assign names to colors and pressure_______*/
#define WHITE   0x0000 //Black->White
#define YELLOW    0x001F //Blue->Yellow
#define CYAN     0xF800 //Red->Cyan
#define PINK   0x07E0 //Green-> Pink
#define RED    0x07FF //Cyan -> Red
#define GREEN 0xF81F //Pink -> Green
#define BLUE  0xFFE0 //Yellow->Blue
#define BLACK   0xFFFF //White-> Black
#define MINPRESSURE 10
#define MAXPRESSURE 1000
/*_______Assigned______*/
/*____Calibrate TFT LCD_____*/
#define TS_MINX 100
#define TS_MINY 85
#define TS_MAXX 965
#define TS_MAXY 905
/*______End of Calibration______*/
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300); //300 is the sensitivity
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET); //Start communication with LCD
String symbol[4][4] = {
  { "7", "8", "9", "/" },
  { "4", "5", "6", "*" },
  { "1", "2", "3", "-" },
  { "C", "0", "=", "+" }
 int X,Y;
 long Num1,Num2,Number;
 char action;
 boolean result = false;
  Serial.begin(9600); //Use serial monitor for debugging
  tft.reset(); //Always reset at start
  tft.begin(0x9341); // My LCD uses LIL9341 Interface driver IC
  tft.setRotation(2); // I just roated so that the power jack faces up - optional
  tft.fillScreen(WHITE);
  IntroScreen();
  draw_BoxNButtons();
TSPoint p = waitTouch();
X = p.y; Y = p.x;
//  Serial.print(X); Serial.print(','); Serial.println(Y);// + " " + Y);
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
  delay(300);
TSPoint waitTouch() {
  TSPoint p;
  do {
    p = ts.getPoint();
    pinMode(XM, OUTPUT);
    pinMode(YP, OUTPUT);
  } while((p.z < MINPRESSURE )|| (p.z > MAXPRESSURE));
  p.x = map(p.x, TS_MINX, TS_MAXX, 0, 320);
  p.y = map(p.y, TS_MINY, TS_MAXY, 0, 240);;
  return p;
void DetectButtons()
  if (X<50 && X>0) //Detecting Buttons on Column 1
    if (Y>0 && Y<85) //If cancel Button is pressed
    {Serial.println ("Button Cancel"); Number=Num1=Num2=0; result=false;}
     if (Y>85 && Y<140) //If Button 1 is pressed
    {Serial.println ("Button 1");
    if (Number==0)
    Number=1;
    Number = (Number*10) + 1; //Pressed twice
     if (Y>140 && Y<192) //If Button 4 is pressed
    {Serial.println ("Button 4");
    if (Number==0)
    Number=4;
    Number = (Number*10) + 4; //Pressed twice
     if (Y>192 && Y<245) //If Button 7 is pressed
    {Serial.println ("Button 7");
    if (Number==0)
    Number=7;
    Number = (Number*10) + 7; //Pressed twice
    if (X<105 && X>50) //Detecting Buttons on Column 2
    if (Y>0 && Y<85)
    {Serial.println ("Button 0"); //Button 0 is Pressed
    if (Number==0)
    Number=0;
    Number = (Number*10) + 0; //Pressed twice
     if (Y>85 && Y<140)
    {Serial.println ("Button 2");
     if (Number==0)
    Number=2;
    Number = (Number*10) + 2; //Pressed twice
     if (Y>140 && Y<192)
    {Serial.println ("Button 5");
     if (Number==0)
    Number=5;
    Number = (Number*10) + 5; //Pressed twic
     if (Y>192 && Y<245)
    {Serial.println ("Button 8");
     if (Number==0)
    Number=8;
    Number = (Number*10) + 8; //Pressed twic
    if (X<165 && X>105) //Detecting Buttons on Column 3
    if (Y>0 && Y<85)
    {Serial.println ("Button Equal");
    Num2=Number;
    result = true;
     if (Y>85 && Y<140)
    {Serial.println ("Button 3");
     if (Number==0)
    Number=3;
    Number = (Number*10) + 3; //Pressed twice
     if (Y>140 && Y<192)
    {Serial.println ("Button 6");
    if (Number==0)
    Number=6;
    Number = (Number*10) + 6; //Pressed twice
     if (Y>192 && Y<245)
    {Serial.println ("Button 9");
    if (Number==0)
    Number=9;
    Number = (Number*10) + 9; //Pressed twice
      if (X<213 && X>165) //Detecting Buttons on Column 3
    Num1 = Number;
    Number =0;
    tft.setCursor(200, 20);
    tft.setTextColor(RED);
    if (Y>0 && Y<85)
    {Serial.println ("Addition"); action = 1; tft.println('+');}
     if (Y>85 && Y<140)
    {Serial.println ("Subtraction"); action = 2; tft.println('-');}
     if (Y>140 && Y<192)
    {Serial.println ("Multiplication"); action = 3; tft.println('*');}
     if (Y>192 && Y<245)
    {Serial.println ("Devesion"); action = 4; tft.println('/');}
    delay(300);
void CalculateResult()
  if (action==1)
    Number = Num1+Num2;
  if (action==2)
    Number = Num1-Num2;
  if (action==3)
    Number = Num1*Num2;
  if (action==4)
    Number = Num1/Num2;
void DisplayResult()
    tft.fillRect(0, 0, 240, 80, CYAN);  //clear result box
    tft.setCursor(10, 20);
    tft.setTextSize(4);
    tft.setTextColor(BLACK);
    tft.println(Number); //update new value
void IntroScreen()
  tft.setCursor (55, 120);
  tft.setTextSize (3);
  tft.println("ARDUINO");
  tft.setCursor (30, 160);
  tft.println("CALCULATOR");
  tft.setCursor (30, 220);
  tft.setTextSize (2);
  tft.setTextColor(BLUE);
  tft.println("-Circut Digest");
  delay(1800);
void draw_BoxNButtons()
  //Draw the Result Box
 //Draw First Column
  tft.fillRect  (0,260,60,60,RED);
  tft.fillRect  (0,200,60,60,BLACK);
  tft.fillRect  (0,140,60,60,BLACK);
  tft.fillRect  (0,80,60,60,BLACK);
 //Draw Third Column
  tft.fillRect  (120,260,60,60,GREEN);
  tft.fillRect  (120,200,60,60,BLACK);
  tft.fillRect  (120,140,60,60,BLACK);
  tft.fillRect  (120,80,60,60,BLACK);
  //Draw Secound & Fourth Column
  for (int b=260; b>=80; b-=60)
 { tft.fillRect  (180,b,60,60,BLUE);
   tft.fillRect  (60,b,60,60,BLACK);}
  //Draw Horizontal Lines
  for (int h=80; h<=320; h+=60)
  tft.drawFastHLine(0, h, 240, WHITE);
  //Draw Vertical Lines
  for (int v=0; v<=240; v+=60)
  tft.drawFastVLine(v, 80, 240, WHITE);
  //Display keypad lables
  for (int j=0;j<4;j++) {
    for (int i=0;i<4;i++) {
      tft.setCursor(22 + (60*i), 100 + (60*j));
      tft.setTextSize(3);
      tft.setTextColor(WHITE);
      tft.println(symbol[j][i]);
Bien évidement, cela ne fonctionne pas. Sinon, je n'aurais pas fait ce post
l'affichage est ok mais tout ce passe comme si le x et le y du capteur sensitif était vu dans un miroir.
gauche inversé avec droite et haut inversé avec bas.
Sinon, ça calcul bien
il s'agit de cet écran
Problème résolu de cette manière :
  tft.setRotation(0); // I just roated so that the power jack faces up - optional
  IntroScreen();
  draw_BoxNButtons();
X = p.y-13; Y = p.x+23;
Ça peut venir de l'orientation de l'écran.
Essayetft.setRotation(0);dans le setup
Le problème vient d'ici
Cette opération change la manière de dessiner à l'écran mais cela n'impacte pas la partie tactile.
2 possibilités pour régler le problème:
  • tu mets l'orientation de l'écran à 0 comme suggéré par lesept
  • si tu ne peux pas (ou ne veux pas) changer l'orientation de l'écran, tu appliques un offset sur les cordonnées retournées par l'écran tactile
salut
Donc, les deux solutions fonctionne.
De mon coté, j'ai fait
  IntroScreen();
  draw_BoxNButtons();
Merci
Tu disais:
Ce n'est pas ce que tu as fait dans ton code, tu as plutôt échangé X (droite/gauche) et Y (haut/bas)X = p.y-13; Y = p.x+23;
j'ai tout essayé ! (enfin, tout est un bien grand mot)
il n'y à que
qui marche.
le code original est celui fourni par le constructeur.
merci
L'important c'est que ça tombe en marche (plus ça rate, plus on a de chances que ça marche)
tu me rappel des bon souvenirs de quand je bossais ! y'avait une bécane qui nous pourrissait bien la vie, et c'est ce qu'on disait "elle est tombée en marche la salope", tous le monde savait de qui on parlait.
bon bin....c'est résolu
