Lighter_Adafruit_GPS.cpp
#include <SoftwareSerial.h>
#include <Lighter_Adafruit_GPS.h>
// how long are max NMEA lines to parse?
#define MAXLINELENGTH 120
// we double buffer: read one line in and leave one for the main program
volatile char line1[MAXLINELENGTH];
volatile char line2[MAXLINELENGTH];
// our index into filling the current line
volatile uint8_t lineidx=0;
// pointers to the double buffers
volatile char *currentline;
volatile char *lastline;
volatile boolean recvdflag;
boolean Lighter_Adafruit_GPS::parse(char *nmea) {
if (nmea[strlen(nmea)-4] == '*') {
uint16_t sum = parseHex(nmea[strlen(nmea)-3]) * 16;
sum += parseHex(nmea[strlen(nmea)-2]);
// check checksum
for (uint8_t i=1; i < (strlen(nmea)-4); i++) {
sum ^= nmea[i];
int32_t degree;
long minutes;
char degreebuff[10];
// look for a few common sentences
if (strstr(nmea, "$GPGGA")) {
// found GGA
char *p = nmea;
// get time
p = strchr(p, ',')+1;
float timef = atof(p);
uint32_t time = timef;
hour = time / 10000;
minute = (time % 10000) / 100;
seconds = (time % 100);
milliseconds = fmod(timef, 1.0) * 1000;
// parse out latitude
if (',' != *p)
strncpy(degreebuff, p, 2);
p += 2;
degreebuff[2] = '\0';
degree = atol(degreebuff) * 10000000;
strncpy(degreebuff, p, 2); // minutes
p += 3; // skip decimal point
strncpy(degreebuff + 2, p, 4);
degreebuff[6] = '\0';
minutes = 50 * atol(degreebuff) / 3;
latitude_fixed = degree + minutes;
latitude = degree / 100000 + minutes * 0.000006F;
latitudeDegrees = (latitude-100*int(latitude/100))/60.0;
latitudeDegrees += int(latitude/100);
if (',' != *p)
if (p[0] == 'S') latitudeDegrees *= -1.0;
if (p[0] == 'N') lat = 'N';
else if (p[0] == 'S') lat = 'S';
else if (p[0] == ',') lat = 0;
else return false;
// parse out longitude
if (',' != *p)
strncpy(degreebuff, p, 3);
p += 3;
degreebuff[3] = '\0';
longitude_fixed = degree + minutes;
longitude = degree / 100000 + minutes * 0.000006F;
longitudeDegrees = (longitude-100*int(longitude/100))/60.0;
longitudeDegrees += int(longitude/100);
if (',' != *p)
if (p[0] == 'W') longitudeDegrees *= -1.0;
if (p[0] == 'W') lon = 'W';
else if (p[0] == 'E') lon = 'E';
else if (p[0] == ',') lon = 0;
else return false;
if (',' != *p)
fixquality = atoi(p);
if (',' != *p)
satellites = atoi(p);
if (',' != *p)
HDOP = atof(p);
if (',' != *p)
altitude = atof(p);
if (',' != *p)
geoidheight = atof(p);
return true;
if (strstr(nmea, "$GPRMC")) {
// found RMC
char *p = nmea;
// get time
// Serial.println(p);
if (p[0] == 'A')
fix = true;
else if (p[0] == 'V')
fix = false;
return false;
if (',' != *p)
p += 2;
long degree = atol(degreebuff) * 10000000;
long minutes = 50 * atol(degreebuff) / 3;
if (',' != *p)
else return false;
if (',' != *p)
p += 3;
if (',' != *p)
else return false;
// speed
if (',' != *p)
speed = atof(p);
// angle
if (',' != *p)
angle = atof(p);
if (',' != *p)
uint32_t fulldate = atof(p);
day = fulldate / 10000;
month = (fulldate % 10000) / 100;
year = (fulldate % 100);
// we dont parse the remaining, yet!
return true;
return false;
//fonction lecture de la classe GPS
char Lighter_Adafruit_GPS::read(void) {
char c = 0;
if(!gpsSwSerial->available()) return c;
c = gpsSwSerial->read();
if (c == '\n') {
currentline[lineidx] = 0;
if (currentline == line1) {
currentline = line2;
lastline = line1;
currentline = line1;
lastline = line2;
lineidx = 0;
recvdflag = true;
currentline[lineidx++] = c;
if (lineidx >= MAXLINELENGTH)
lineidx = MAXLINELENGTH-1;
return c;
//constructeur du GPS
Lighter_Adafruit_GPS::Lighter_Adafruit_GPS(SoftwareSerial *ser)
common_init(); // Set everything to common state, then...
gpsSwSerial = ser; // ...override gpsSwSerial with value passed.
// Initialization code used by all constructor types
void Lighter_Adafruit_GPS::common_init(void) {
gpsSwSerial = NULL; // Set both to NULL, then override correct
// gpsHwSerial = NULL; // port pointer in corresponding constructor
recvdflag = false;
// paused = false;
lineidx = 0;
lastline = line2;
hour = minute = seconds = year = month = day =
fixquality = satellites = 0; // uint8_t
lat = lon = mag = 0; // char
fix = false; // boolean
milliseconds = 0; // uint16_t
latitude = longitude = geoidheight = altitude =
speed = angle = magvariation = HDOP = 0.0; // float
//fonction initialisation GPS
void Lighter_Adafruit_GPS::begin(uint16_t baud)
gpsSwSerial->begin(baud);
delay(10);
//fonction d'envoie des demandes du GPS
void Lighter_Adafruit_GPS::sendCommand(const char *str) {
gpsSwSerial->print(str);
//fonction de nouvelle reception GPS
boolean Lighter_Adafruit_GPS::newNMEAreceived(void) {
return recvdflag;
//fonction ancienne reception GPS
char *Lighter_Adafruit_GPS::lastNMEA(void) {
recvdflag = false;
return (char *)lastline;
//fonction de convertisseur
// lecture en hexa et renvoie en decimal
uint8_t Lighter_Adafruit_GPS::parseHex(char c) {
if (c < '0')
return 0;
if (c <= '9')
return c - '0';
if (c < 'A')
return 0;
if (c <= 'F')
return (c - 'A')+10;
// if (c > 'F')
return 0;
