Hi, it's me from the 74HC595 topic !
For the guys who helped me in this topic
the 0.1µF caps make a strange behaviour on my light bar so I removed them
Now, it's time to add the IR Receiver !
Which way is the best to make an interrut system with the IR ?
- Serial Communication (Tried, worked but not optimized in my opinion)
- Interrupt pin (3) (Tried and not working)
- other ?
Libraries : ShiftRegisterPWM, IRRecv
It is best not to use Serial pins for stuff that does not use serial……
b707
3
Why did you open a new thread rather than continue in the previous one?
b707
4
Please explain, how can a IR interrupt be added via Serial?
Because that's a question and not a problem
With another Arduino board that sends serial data (that's why I think it's not optimized)
Yes I agree ...
b707
6
I don't think this a good idea.
Why don't use a interrupt dedicated pins - 2 or 3 ? (on Uno/Nano)
Why don't use a interrupt dedicated pins - 2 or 3 (on Uno/Nano)
I've found some topics that say something about disabled interrupts because of uploading time
Also I've already tried to do this but didn't work
b707
8
During an upload, not only interrupts are disabled - during this time, no code runs except the bootloader.
So show your code and connection diagram
Connection diagram is at top of the topic ^^'
#define ShiftRegisterPWM_CLOCK_PORT PORTD
#define ShiftRegisterPWM_CLOCK_MASK 0B00100000
#include <IRremote.hpp>
#include <ShiftRegisterPWM.h>
ShiftRegisterPWM sr(3, 8);
IRrecv irrecv(3);
decode_results results;
bool hasReceivedIR = false;
attachInterrupt(digitalPinToInterrupt(3), InterruptLightBar, RISING);
pinMode(2, OUTPUT); // sr data pin
pinMode(5, OUTPUT); // sr clock pin
pinMode(4, OUTPUT); // sr latch pin
irrecv.start();
irrecv.enableIRIn();
sr.interrupt(ShiftRegisterPWM::UpdateFrequency::Fast);
for (int led = 0; led < 24; led++) {
sr.set(led, 0);
LightBar();
void LightBar(){
if (irrecv.decode(&results)){
switch (results.value) {
case 0xFFFFFFFF:
for (int i = 0; i < 255; i++) {
if (hasReceivedIR) return;
sr.set(led, i);
void InterruptLightBar(){
hasReceivedIR = true;
b707
10
Note that any variables, that should be changed inside the interrupt, must be declared as volatile.
Could you explain in more detail, what is nor works in the code?
dj_math
11
Well uhh forgot some lines, now it's working by println debug (will be removed)
But the IRRecv library is kinda weird, the decode function is not defined (error at console) and the decode_results is deprecated ??
dj_math
13
Oh crap, the #include <IRemote.hpp> has been invisible until now ...
Changed to IRemote.h
b707
14
Yes, it's been a long time
There should be a new example without using it in the library
b707
16
Did you read a README file on the library repository?
dj_math
17
Nop, I never know that the v2 is deprecated ...
dj_math
19
That's a big migration to do
Well anyways thank you for your help !
alto777
20
Do you mean the recommended capacitor near the IC, wired from 5 volts to GND? One 0.1 uF cap per chip.
I'm not believing you tried that and it caused problems, please tell us more.
a7
