[RESOLVED] error: expected ';' at end of member declaration
Hi all,
I have a compilation error I don't understand for a little tiny class. At compilation it complains that he needs a semicolon.
Have you any idea why ?
// tools.h
#ifndef daap_tools_h
#define daap_tools_h
class Tools {
  public:
  static int toInt(char c);
  static char* toTwoChar(byte b);
#endif
// tools .cpp
#include "tools.h"
int Tools::toInt(char c) {
  return (int)(c - 48);
char* Tools::toTwoChar(byte b) {
  byte dizaines = b / 10 ;
  byte unites = b - dizaines*10;
  char res[3] = {'0' + dizaines, '0' + unites, '\0'};
  return res;
You can see complete compilation error here : GDB online Debugger | Code, Compile, Run, Debug online C, C++
Thanks,
Phaust
You get 3 errors, none of which are probably what you are trying to do, but all 3 are for the line
Looking at this, I can see this is incorrect syntax for a function pointer, if that is what you are trying to do, but I am not sure what you are trying to do with this line.
#endif
why is that semicolon there? what does it do?
  return res;
Oops
[quote author=Geek Emeritus link=msg=4208920 date=1560432097]
#endif
[/quote] Ends the class.
Class names end with a semicolon.
Perehama:
The method transforms a byte to its string (char*) equivalent. This is not a function pointer but a function returning a char pointer (this is what I want, I would like to do).
But you're returning a pointer to a non-static local variable, so by the time you use it, the memory it points to could already have been repurposed.
PhaustSceptic:
You want to pass the value of the byte or the address of the byte?
Except memory usage problems or other type of execution problems (I will quickly checks that :D) why the code does not compile ?
I add the static keyword to be able to access the method without the need of instantiate the class. But removing it does not change the compilation error.
I found it !
I need to add the following include in order to get access to the byte type...
#include <arduino.h>
Now, removing programming errors :smiley:
Thanks all,
Phaust.
The correct filename is Arduino.h. Although you can may (depending on where you use it) get away with arduino.h on a filename case-insensitive OS like Windows, this will not work on a case sensitive OS like Linux. Correct filename case is required for #include directives in Arduino sketches even on Windows. So it's best to always use the proper filenames.
