Edit: The compilation errors occur because the first parameter needs to be uint8_t.
https://www.arduino.cc/en/serial/write
I am having some trouble decrypting my compilation errors. The documentation isn't quite clear on the parameters, but I can't even tell which parameter the errors are talking about; the first or the second.
Note: I am using an ESP32, so the libraries might not be the same, but I thought they should be the same.
#include "FS.h"
#include "SD.h"
#include "SPI.h"
char buff[20] = "1234567890123456789";
int c = 19;
File file = SD.open("test.txt", FILE_APPEND);
file.write(buff, c);
Serial.write(buff, c);
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "ESP32 Pico Kit, 921600, None"
C:\...\AppData\Local\Temp\arduino_modified_sketch_219423\sketch_apr30a.ino: In function 'void setup()':
sketch_apr30a:12:21: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
In file included from C:\Users\Sean\AppData\Local\Temp\arduino_modified_sketch_219423\sketch_apr30a.ino:1:0:
C:\...\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.2\libraries\FS\src/FS.h:55:12: note: initializing argument 1 of 'virtual size_t fs::File::write(const uint8_t*, size_t)'
size_t write(const uint8_t *buf, size_t size) override;
sketch_apr30a:13:23: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
In file included from C:\...\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Arduino.h:160:0,
from sketch\sketch_apr30a.ino.cpp:1:
C:\...\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.2\cores\esp32/HardwareSerial.h:67:12: note: initializing argument 1 of 'virtual size_t HardwareSerial::write(const uint8_t*, size_t)'
size_t write(const uint8_t *buffer, size_t size);
Multiple libraries were found for "SD.h"
Used: C:\...\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.2\libraries\SD
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\SD
exit status 1
option enabled in File -> Preferences.
