I've done completely mess I upgraded my yun through "PUTTY" with the file "openwrt-ar71xx-generic-yun-16M-rootfs-squashfs.bin" and now I can not do more to recognize my Arduino on the my network .. let alone on "IDE (1.6.5)" .. what can I do?
I did:
1 - open "PUTTY" entered the IP address of 192.168.1.2 my yun
5 - did the reboot does not work anymore ... nothing .. = (
even PUTTY not have plus communication. if pinging the old (even tried the default 192.168.240.1 and others) address did not answer
I tried several times, but the button reset on the my yun not did return on basic, defaul state. The WEBpanel not entry (Error HTTP 404.0 - Not Found) and in my
device management i see my arduino yun but with error (28)
P.S. when was all right.. =) the version IDE 1.6.6 and 1.6.7 not worked in my windows system.
Upload this to an Arduino Yún via serial (not WiFi) then open the serial monitor at 115200 to see the boot process of Linux. You can also use the serial monitor as a basic command line interface for Linux using this sketch
I finally got a bit of time and I fixed thanks to you.
Before i had to recognize the COM port on my PC. She did not want in any way.
I simply used a different USB port and it has been recognized. Then i simply connected the Ardu through a router to the same network as my pc. (my mistake:before i had the Ardu directly connected to my PC and was not detected).
Finally by the web panels i have charged the latest relase.
