Retrieving HTTP:// document as $variable
Hi there
Would it be possible to obtain an integer $variable from an http://..../file.php, say "5" and store in the Arduino code as the $variable?
Using the HTTP GET protocol, whenever required?
How would this be possible? I have so far been using things like substring & XML from old forum posts - yet are quite cumbersome - so is there a simpler, newer approach?
thanks
Calum
You can get the value, if the script outputs the value.
No.
in what way is it possible to obtain the value?
In your php script, say "echo $variable."
In your sketch, create a client object and call client.read().
It's not very graceful but it is possible.
Telepathy, osmosis, divination,...
What does the php script do? It should generate some kind of output. That output is what is received as a result of the GET command.
If the php script contains
$i = 3;
and the output that it produces is:
You lose
I am not going to tell you about $i
then there is no way to get the value.
If, on the other hand, the output is
$i = 3
then it isn't rocket science to extract the value from the stream.
