New here so please be gentle
I'm using an Arduino for a camera slide project, needing a lot of text strings for the LCD menu system, so have opted to store these strings in an external eeprom.
Each string (max chars 20) is stored at the begiing of a page boundary, wastefull but should simplify the code as I won't need to worry about splitting strings across a boundary etc.
I can store the stings with now issue, I can also retrieve them BUT when I try to Serial.println(string) I loose the first byte.
I've spent all afternoon going around in circles!
I know I'm doing something stupid (as usual) but am in need of some pointers (please excuse the pun)....
Method 3 fails every time...So here we go, here's my code:
#include <Wire.h>
byte deviceaddress = 0x50;
const int numberOfTextLines = 4;
const int maxCharsPerLine = 20;
unsigned char dataFromEeprom[maxCharsPerLine];
char lcdTextBuffer;
bool flag=false;
// Start with a small array & see if I can manipulate this!
char lcdTextData[numberOfTextLines][maxCharsPerLine]={
  "Select Mode",      // 0 eeprom write byte location 0
  "Simple Time Lapse",   // 1 eeprom write byte location 64
  "Advanced Time Lapse",  // 2 eeprom write byte location 128
  "Day-Time Videos"    // 3 eeprom write byte location 192 etc.
 Wire.begin();
void writeEEPROM(int deviceaddress, unsigned int eeaddress, char* data)
 // Write a string of chars to eeprom
 // Only works upto page boundary
 // This is OK here as I'm only storing strings of max length 20 charsÂ
 unsigned char i=0;
Â
 Wire.beginTransmission(deviceaddress);
 Wire.write((int)((eeaddress) >> 8)); // MSB
 Wire.write((int)((eeaddress) & 0xFF)); // LSB
 do{
  Wire.write((byte) data[i]);
  i++;
 } while(data[i]);Â
 Wire.endTransmission();
 Â
 delay(6); // needs 5ms for page write
void readEEPROM(int deviceaddress, unsigned int eeaddress,Â
        unsigned char* data, unsigned int num_chars)
 unsigned char i=0;
 Wire.write((int)(eeaddress >> 8)); // MSB
 Wire.write((int)(eeaddress & 0xFF)); // LSB
 Wire.requestFrom(deviceaddress,num_chars);
 while(Wire.available()) data[i++] = Wire.read();
Â
  if(flag==false){
  Â
   int eeaddress = 0;
   int numCharsToRead = 20; // this will need changing later for lookup table
 Â
  for(int i=0; i<numberOfTextLines;i++){
     char *tempStringBuffer = lcdTextData[i];
    Â
     writeEEPROM(deviceaddress,eeaddress,tempStringBuffer);
    Â
     Serial.print("1 : ");      // This works
     Serial.println(tempStringBuffer);
    Â
     Serial.print("2 : ");
     Serial.println("OK let's see if we can read this back");
    Â
     readEEPROM(deviceaddress,eeaddress,dataFromEeprom,numCharsToRead);
     *tempStringBuffer = (dataFromEeprom,numCharsToRead);
     Serial.print("3 : ");       // This does NOT work always looses the first byte?
     // eventually I want to display this on an LCD
    Â
     Serial.print("4 : ");
     Serial.println("Actual string stored");
    Â
     Serial.print("5 : ");       // This works
     Serial.write(dataFromEeprom,numCharsToRead);
    Â
    Â
     Serial.print("6 : ");
     eeaddress+=64;
     Serial.println(eeaddress);
   flag=true;
  }Â
