I did some retro sounds with the arduino:
(AlienBird, AlienUfo, AlterMotor, Laser1, TimeUp, IntoWarp)
Hardware was just a simple 1bit to Lineout RC, then recorded with Audacity.
I cant give you the exact code, as it evolved over time and some effects I was never able to reproduce (also used some modulation with 2 potis). Here is a code which uses some LFO modulation:
Verrückte Töne kontrolliert von zwei Potis (oder Kreuzknüppel)
April 2009 Carsten Wartmann
cw (*) blenderbuch.de
#define BEEP 12 // Ausgangspin im einfachsten Fall direkt an einen Piezo-Schallwandler
#define POTX 4 // Analog 4
#define POTY 5 // Analog 5
// Das Lesen der Potis geschieht in einem Interrupt
#include <MsTimer2.h>
volatile long pitchval = 1;
volatile long delayval = 1;
volatile int LFO=1;
volatile int LFOD = 3;
pinMode(BEEP,OUTPUT);
// Init und Start der Interrupt-Routine
MsTimer2::set(2, getPots); // Alle 5ms
MsTimer2::start();
// freqout code by Paul Badger
// freq - frequency value
// t - time duration of tone
// Angepasst für "lustige Töne"...
void freqout(int freq, int t)
long hperiod; //calculate 1/2 period in us
long cycles, i;
// subtract 7 us to make up for digitalWrite overhead - determined empirically
hperiod = (50130000 / ((freq - 7) * pitchval));
// calculate cycles
cycles = ((long)freq * (long)t) / 1000; // calculate cycles
for (i=0; i<= cycles; i++)
{ // play note for t ms
digitalWrite(BEEP, HIGH);
delayMicroseconds(hperiod*LFO/10);
digitalWrite(BEEP, LOW);
delayMicroseconds((hperiod - 1)*LFO/10); // - 1 to make up for fractional microsecond in digitaWrite overhead
// Interrupt Routine
void getPots()
pitchval = analogRead(POTX);
delayval = analogRead(POTY)-250; // Y Poti ist leider defekt...
LFO=LFO+LFOD;
// Triangle
if (LFO>100 || LFO<1)
LFOD=LFOD*-1;
// Sägezahn
if (LFO>100)
LFO=1;
int ran = 150;
freqout(440+random(ran),delayval);
// delay(delayval/2);
freqout(340+random(ran),delayval);
freqout(240+random(ran),delayval);
delay(delayval/2);
Best regards,
Carsten
