I’m diving into a new project building an interactive controller to drive real-time visuals in TouchDesigner, and I'd love to get your insights to validate my shopping cart before I pull the trigger.
The core idea: I salvaged a super stylish vintage telephone keypad, but it only has 4 wires coming out of it (see attached photos). My goal is to send every keypress over to TouchDesigner via serial communication.
I have a few questions regarding feasibility and hardware choices:
Handling Keypress States: For my visuals, I want to be able to handle two different behaviors. Either a short press (just a quick pulse from 0 to 1), or detecting when I hold the key down (the signal stays at 1 for as long as my finger is on the button). Is this easy to handle on the coding side?
The Decoder: With only 4 wires for 12 keys, I strongly suspect this thing uses DTMF (dual-tone multi-frequency). Is an MT8870 decoder module absolutely necessary to translate this cleanly, or is there a trick I'm missing?
The Microcontroller: I found an ESP32 development board featuring a 1.9" TFT ST7789 LCD screen (135x240) and USB-C. Does this specific board have enough available GPIO pins left for the project, considering the built-in screen already uses quite a few internally? I’m really leaning towards the ESP32 for the zero-latency performance and the built-in Wi-Fi/Bluetooth in case I want to go wireless down the road.
Cabling & Breadboarding: To hook everything up cleanly without breaking out the soldering iron on day one, what type of jumper wires do you recommend (Dupont M-M, M-F?) and what size breadboard should I look for?
The Motion Sensor: On top of the keypad, I want to integrate a sensor to track position in space (X, Y, Z axes) and hopefully rotation, so I can tweak my visual effects when moving the module around. What reliable, precise IMU sensor would you recommend that plays nice with the ESP32? (I've heard a lot about the MPU-6050, does that sound like the right call?).
The ultimate goal is to centralize the keypad + the motion sensor on the ESP32 and stream everything together over USB to TouchDesigner.
Thanks a ton in advance for your feedback and expert advice!
You'll need to know how the keypad works. A web search might turn up someone's efforts to reverse engineer it, or if you are lucky, the original schematic.
The Decoder It's 100% a decimal (pulse) keypad (from an S63). It has a tuning screw on the back marked 500 / 800. Since it's pulse-based, I guess I can skip the MT8870 decoder entirely and read the pulses directly with the ESP32 using interrupts, right?
because of the onboard facilities (display, touchscreen, SD reader, etc) in general the number of GPIOs available externally on these displays is very limited
check the hardware specification to see what GPIOs are brought out
Thanks for the warning! I actually double-checked the manufacturer's pin mapping for this specific Ideaspark 1.14" board, and it turns out the onboard screen only uses 6 pins: D2, D4, D15, D18, D23, and D32. So I’m in luck there are still plenty of free GPIOs available on the sides.
Also, some good news on the hardware side: I confirmed that my vintage phone keypad is 100% a decimal pulse system (an old French HPE Bonneville unit). Because it just generates raw electrical impulses instead of DTMF tones or a matrix grid, I only need to use 2 basic digital pins to read it (one for counting the pulses via interrupts and one for the key-down state).
For the motion sensor, I can just use the standard, completely free ESP32 hardware I2C pins (GPIO 21 for SDA and GPIO 22 for SCL).
