LarryD
November 22, 2015, 5:29am
1
Please move to Programming.
In the example below, does using return mess up the stack?
pinMode(13,OUTPUT);
digitalWrite(13, !digitalRead(13));
delay(100);
while(1)
return;
I should ask, does while(1) uses the stack?
MorganS
November 22, 2015, 5:59am
2
Have you had your stacks messed up in the past? What specific problem do you think you are avoiding?
No and No.
LarryD
November 22, 2015, 6:15am
3
I have used return; inside of loop() to bypass code.
ex:
if( continueState == true) return;
This works well for the times I use it.
Then at 4 AM I woke up and asked my wife if "while" pushes anything on the stack.
She kicked me out of bed.
Then I thought if there would ever be an case were using "return" inside loop would be a bad thing.
Hence the question.
Thanks and Thanks
Why would it?
This was a bad dream, right?
LarryD
November 22, 2015, 6:23am
5
I guess when you come to the closing brace in, while, it use a goto jmp to get back the the first line in while.
Very bad dream
You could find that out by disassembling the code, but yes, that is correct.
Paul_B
November 22, 2015, 7:54am
7
LarryD:
Correct me if I am wrong, but the word for which you are looking, is "break ".
Depends how much code he wants to bypass.
MarkT
November 22, 2015, 10:38am
9
The compiler knows about how to manage a stack, don't worry about that!
It's probably not a bright idea to return from loop() even if the compiler might correct that.
Looking at main.cpp, does return even get you out of loop() ? Since loop() is within an infinite for loop, doesn't return just end up calling loop() again? What about a call to exit() , even though it's a little ugly.
please note the compiler will probably optimize this specific example to
pinMode(13,OUTPUT);
delay(100);
every return in loop() ends the call to loop() from main(), so before calling loop again some other things are done, e.g. checking Serial events
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
That said, some style guides dictate that every function should only have one place it exits.
econjack:
I hadn't looked. So that's how they idiot-proof? I like!
IIRC exit() actually turns some AVR functions off.
If so it may use less power than
while (1) {};
do not forget the interrupts...
noInterrupts(); // prevents code running in interrupt mode
while(1);
LarryD
November 22, 2015, 5:31pm
17
You would think after 40 years there would be some indulgence.
But, then again maybe not
GoForSmoke:
while (1) {};
It turns interrupts off, that's about all.
