Return struct from a function
Hey!
I wrote/complied some code to get some data from sensors and now Im trying to split some of it up into libraries to make the code look "cleaner". I have one function that returns 3 values, so Im using a struct to do so, but Im having a little trouble with it.
Here is the main code
#include <SPI.h>//SPI communcation library
#include <Wire.h>//I2C communcation library
//These libraries came with Compass
#include <FreeSixIMU.h>//Reading data from Acc anf Gyro
#include <FIMU_ADXL345.h>//Digital Accelerometer
#include <FIMU_ITG3200.h>// triple-axis MEMS gyroscope and temperature
#include <HMC5883L.h>// 3-Axis Digital Compass
#include <BMP085.h>//Digital Pressure Sensor
#include <Sonar.h>
#include <Pressure.h>
const int clock = 9;// generate a MCKL signal on pin 9 for use with SPI
float angles[3]; // yaw pitch roll
float heading;
//float tempReal,tempComp;
long internalPressure;
//long externalPressure;
long tempDOF;//internal temperature measured by DOF compass
int humidityCurrent, humidityPrevious, humidityTemp,deltaHumidity,tempPhidget,relativeHumidity;
word range;//range of Sonar
struct pressureData{
	float tempReal;
	float tempComp;
pressureData pres;
// Set the FreeSixIMU object
FreeSixIMU sixDOF = FreeSixIMU();
HMC5883L compass;
// Record any errors that may occur in the compass.
int error = 0;
void setup(){
      Serial.begin(9600);//9600 baud rate for TX0, RX0
      Serial1.begin(9600);//9600 baud rate for TX1, RX1
      Wire.begin();//start I2C communcation
      //pressure
      SPI.begin(); //start SPI communcation
      SPI.setBitOrder(MSBFIRST);
      SPI.setClockDivider(SPI_CLOCK_DIV32); //divide 16 MHz to communicate on 500 kHz
      pinMode(clock, OUTPUT);
      delay(100);
void loop(){
      //sonar
     takeRangeReading(); //Tell the sensor to perform a ranging cycle
     delay(100); //Wait for sensor to finish
     range = requestRange(); //Get the range from the sensor
     getHeading();
     getPhiget();
     resetPressureSensor();//You may have to go into Pressure.h and mess around with variable location
     pres = getPressure();
     printData();
     delay(300);
printData
This function takes all the data from the sensors and sends it to the  TX1 pin. It also adds in the
tags for each sensors data and comma delimiters
void printData(){
     Serial1.print("PRESS");
     Serial1.print(",");
     Serial1.print(pres.tempReal);
     Serial1.print(",");
     Serial1.print(pres.externalPressure);
     Serial1.print(",");
     Serial1.print(pres.tempComp);
     Serial1.println(",");
Here is the header file getPressure (the one giving me errors)
#include <Arduino.h>
void resetPressureSensor();
struct pressureData getPressure();
Here is the library file getPressure (the one giving me errors)
#include "Pressure.h"
resetPressureSesnor
this resets the pressure sensor. BUT WHY AMND HOW
	float tempReal;
	float tempComp;
pressureData pres;
struct pressureData getPressure(){
      TCCR1B = (TCCR1B & 0xF8) | 1 ; //generates the MCKL signal
      analogWrite (clock, 128) ;
      resetPressureSensor();//resets the sensor - caution: afterwards mode = SPI_MODE0!
      //Calibration word 1
      unsigned int result1 = 0;
      unsigned int inbyte1 = 0;
      SPI.transfer(0x1D); //send first byte of command to get calibration word 1
      SPI.transfer(0x50); //send second byte of command to get calibration word 1
      SPI.setDataMode(SPI_MODE1); //change mode in order to listen
      result1 = SPI.transfer(0x00); //send dummy byte to read first byte of word
      result1 = result1 << 8; //shift returned byte
      inbyte1 = SPI.transfer(0x00); //send dummy byte to read second byte of word
      result1 = result1 | inbyte1; //combine first and second byte of word
      //Calibration word 2; see comments on calibration word 1
      unsigned int result2 = 0;
      byte inbyte2 = 0;
      SPI.transfer(0x1D);
      SPI.transfer(0x60);
      result2 = SPI.transfer(0x00);
      result2 = result2 <<8;
      inbyte2 = SPI.transfer(0x00);
      result2 = result2 | inbyte2;
      //Calibration word 3; see comments on calibration word 1
      unsigned int result3 = 0;
      byte inbyte3 = 0;
      SPI.transfer(0x1D);
      SPI.transfer(0x90);
      result3 = SPI.transfer(0x00);
      result3 = result3 <<8;
      inbyte3 = SPI.transfer(0x00);
      result3 = result3 | inbyte3;
      //Calibration word 4; see comments on calibration word 1
      unsigned int result4 = 0;
      byte inbyte4 = 0;
      SPI.transfer(0x1D);
      SPI.transfer(0xA0);
      result4 = SPI.transfer(0x00);
      result4 = result4 <<8;
      inbyte4 = SPI.transfer(0x00);
      result4 = result4 | inbyte4;
      //now we do some bitshifting to extract the calibration factors
      //out of the calibration words; read datasheet AN510 for better understanding
      long c1 = result1 >> 3 & 0x1FFF;
      long c2 = ((result1 & 0x07) << 10) | ((result2 >> 6) & 0x03FF);
      long c3 = (result3 >> 6) & 0x03FF;
      long c4 = (result4 >> 7) & 0x07FF;
      long c5 = ((result2 & 0x003F) << 6) | (result3 & 0x003F);
      long c6 = result4 & 0x007F;
      //Temperature:
      unsigned int tempMSB = 0; //first byte of value
      unsigned int tempLSB = 0; //last byte of value
      unsigned int D2 = 0;
      SPI.transfer(0x0F); //send first byte of command to get temperature value
      SPI.transfer(0x20); //send second byte of command to get temperature value
      delay(35); //wait for conversion end
      tempMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value
      tempMSB = tempMSB << 8; //shift first byte
      tempLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value
      D2 = tempMSB | tempLSB; //combine first and second byte of value
      //Pressure:
      unsigned int presMSB = 0; //first byte of value
      unsigned int presLSB =0; //last byte of value
      unsigned int D1 = 0;
      SPI.transfer(0x0F); //send first byte of command to get pressure value
      SPI.transfer(0x40); //send second byte of command to get pressure value
      presMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value
      presMSB = presMSB << 8; //shift first byte
      presLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value
      D1 = presMSB | presLSB; //combine first and second byte of value
      //calculation of the real values by means of the calibration factors and the maths
      //in the datasheet. const MUST be long
      const long UT1 = (c5 << 3) + 10000;
      const long dT = D2 - UT1;
      const long TEMP = 200 + ((dT * (c6 + 100)) >> 11);
      const long OFF  = c2 + (((c4 - 250) * dT) >> 12) + 10000;
      const long SENS = (c1/2) + (((c3 + 200) * dT) >> 13) + 3000;
      pressureData.externalPressure = (SENS * (D1 - OFF) >> 12) + 1000;
      pressureData.tempReal = TEMP/10;
      //2nd order compensation only for T > 0°C
      const long dT2 = dT - ((dT >> 7 * dT >> 7) >> 3);
      pressureData.tempComp = (200 + (dT2*(c6+100) >>11))/10;
       //delay(5000);
	  return pressureData;
void resetPressureSensor(){
      SPI.setDataMode(SPI_MODE0);
      SPI.transfer(0x15);
      SPI.transfer(0x55);
      SPI.transfer(0x40);
I figured it out. I hadnt named the struct properly in the library
Instead of using a struct, you can just make a function that can do this for you.
Maybe a little overkill tho.
class myValues
  public:
    int a, b, c;
    myValues() // initial constructor
      a = b = c = 0;
    myValues(int A, int B, int C) // second constructor that gets data and stores it
      a = A;
      b = B;
      c = C;
    myValues data() // a function to add in values, return type must be the class name
      return myValues(45, 200, 35);
//---------------END_OF_CLASS----------------
myValues mVal; // constructor
  myValues D = mVal.data(); // call the data function which puts some values into the second constructor, then
                            // using another constructor, you collect that data.
  Serial.println(D.a);
  Serial.println(D.b);
  Serial.println(D.c);
output:
45
200
35
It's generally easier to use reference variables.
void someFun(int iOne, int iTwo, int &oSum)
   oSum = iOne + iTwo;
Then call the function:
   int a = 14;
   int b = 2;
   int c;
   someFun(a, b, c);
   Serial.print("c = ");
   Serial.println(c);
This will print c = 16.
