Return value of bitRead() function
1. According to Arduino document, the bitRead() function returns 0 or 1. Which one of the following is more correct?
byte y = 0b01011011;
int n = bitRead(y, 1);
Or
bool n = bitRead(y, 1);
2. Does 1/0 stand for HIGH/LOW or true/false or integer?
  • My understanding is we get 1 or 0
  • I use this when need to do digitalWrite.
digitalWight(MyPin, bitRead(y, 1) == 1 ? HIGH : LOW);
I understand that you support:
I would write:
digitalWrite(MyPin, n);
Fixed the foobarred spelling, sorry.
I would say equally correct.
In C, zero is false and any other value is true, so that implicit conversion should be safe.
Either true/false or integer is safe.
But HIGH/LOW is not quite so simple. I don't know if Arduino has guaranteed that HIGH will always and forever be 1 and LOW will always and forever be 0. I think they would be absolutely crazy to change that, but...
This is bitRead
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
Based on that my take is that it returns a form of integer (byte, int).
I believe (on AVRs) bools are stored in a uint8_t (byte), don't know about 32 bit processors.
I believe boolean functions only see the LSB (least significant bit) of the addressed variable?
  • Hum, :thinking:
    Are you suggesting B0000010 is false ?
byte n = B0000010;
if( n == false)
Say:
value = 00101111
bit = 4
Reurn vlaue = (((value) >> (bit)) & 0x01)
===> Return value = 00000010 & 00000001 = 00000000 (byte)
Arduino document says that the return value is: 0 or 1
If the variable type is bool, yes.
I would write as follows as my intention is to do an arithmetic operation.
byte n = B0000010;
if( n == 0x02)
It is not equal to true.
  Serial.println("Hi Mom!\n");
  int x = 42;
  bool y = true;
  if (x) Serial.println("x (42) is true");
  if (y) Serial.println("y (true) is true");
  if (x == y) Serial.println("this does not print");
It makes comparing logical flags a little tricky? So maybe
bool n = bitRead(y, 1) != 0;
You can also booleanize a variable with !!, but it's not seen so much in the wild. At least I don't see it very often:
bool n = !!bitRead(y, 1);
a7
Oh well, another belief down the ol' porcelain convenience. :grimacing:
This depends on the type of y and the implicit type promotion rules. In your case, an int is returned.
The following snippet can be used to explore what happens in different cases (tested on a Mega 2560).
template <class T> String show(T const) {
  String s(__PRETTY_FUNCTION__);
  return s.substring(25, s.length() - 1);
  byte a {};
  auto r {bitRead(a, 1)};
  Serial.println(show(r));  // Prints "int".
  uint16_t b {};
  auto s {bitRead(b, 1)};
  Serial.println(show(s));  // Prints "unsigned int".
void loop() {}
