Returning an array
I'm trying to figure out how to return an array from a function.
I can return the array itself with the below code but I can't figure out how to recieve an element from that array.
  Serial.begin (115200);
  int ret = Test();
  Serial.println(ret);
int Test(){
  int test[] = {1,2,3};
  return test;
Any tips would be appreciated.
You can return a struct containing an array, but I don't think you can return an array by itself.
What are you trying to do?
Use pointers.
Paul
Paul_KD7HB:
Use pointers.
Paul
...but not to an automatic variable within the function returning the pointer.
As stated, use pointers. But, then the local variable being returned must be 'static'. Also, you need some way of knowing the array's size in the calling function:
  int *returnedArray;
  returnedArray = Test();
  for (uint8_t i = 0; i < 3; i++) {
    Serial.println(returnedArray[i]);
int *Test() {
  static int test[] = {1, 2, 3};
  return test;
As also previously stated, a more common technique would be to allocate the array storage in the calling program and pass a pointer to it (along with array size) to the function:
  const uint8_t arraySize = 3;
  int myArray[arraySize];
  test(myArray, arraySize);
    Serial.println(myArray[i]);
void test(int *theArray, size_t numElements) {
  for (uint8_t i = 0; i < numElements; i++) {
    theArray[i] = i;
Thanks a million guys. I will give this a shot but I'm sure I won't have any problems now.
gfvalvo:
    theArray[i] = i;
I do have one more question that will help me understand your code. What dose the "*" mean in front of *theArray? The code does work without it.
Thanks
KrafterHD:
Thanks
The * indicates a pointer.
Without it, the code DOES NOT work.
It won't even compile.
KrafterHD:
Thanks
AWOL:
Now I know. Thank you very much. The code works great and can be easily modified for my needs.
Perehama:
* - Arduino Reference
Great. Thanks. I tried googling it but didnt come up with anything.
