i cant recive any message ... i'm trying this with rx on duemilanove pin 11, tx on mega pin 40 :
#include <VirtualWire.h>
Serial.begin(9600); // Debugging only
Serial.println("setup");
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf[i], HEX);
Serial.print(" ");
Serial.println("");
digitalWrite(13, false);
and this on mega
vw_set_tx_pin(40);
const char *msg = "hello";
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait until the whole message is gone
delay(200);
Have you tried NOT calling vw_set_ptt_inverted()?
I have used that RF pair successfully and I did not call vw_set_ptt_inverted() on either my transmitter nor on my receiver.
Have you tried NOT calling vw_set_tx_pin() on the transmitter and using the default pin 12? I don't have a Mega, but I believe PWM (needed by VirtualWire) is only supported on pins 0 thru 13.
yes i tried not calling the inverted function and no luck, and for the tx pin i thought he need a digital pin as in doc it said :
4.1vw_set_tx_pin
extern void vw_set_tx_pin(uint8_t pin);
Set the digital IO pin to use for transmit data. Defaults to 12.
so i placed my connection on digital IO pin 40. i didnt know that he need a PWM out, i thought the library would make the correct frequency and interput.
ill give it a try in a few minutes and let you know
