Hello,
I'm playing with the Arduino for about a month, and I've stucked I've got: 2 Arduinos, RF transmitter, RF reciever, button and LED. My project is very simple - when I'm pressing the button, LED connected to another Arduino is turning ON. For about a day I was able to control LED from another room and everything worked fine. Yesterday I backed to my project again, and the distance that I was able to reach had shrinked to 1 meter! Today it suprised me with 1-2 centimeters max range. I'm guessing that tomorrow it won't work completely. The best thing is, that I've tried
changing RF modules to new pair
changing power supplies
soldering an external 17cm antenna
even changing the Arduinos.
Anybody can tell me what the hell is going on? It is the same code, same room, and exacly same desk as with the first test.
I've tried with many power sources: my PC, external power supply and even powerbanks.
Interference? It worked about a weak ago without any problems, a day before yesterday it worked for max 1 m, and today it is 1 cm. Interference is increasing from day to day?
Have you put antenna wires on them? 17cm of 30 gage single strand wirewrap wire worked on my project, transmitter is a remote powered from single LiPo powering a 8MHz Promini, receiver is 5V powered and receives from up to 50 feet away in a large open room.
Yes I have and the distance has increased to ~7m. The thing that really annoy me is, that it has worked fine without any antennas or higher voltage, now it don't. Everything is same as in the first test.
Obviously, everything is not "the same". You have not figured out what changed.
I get about 300 meters line of sight range using those modules, and balanced dipole antennas, as shown below (33 cm from tip to tip, connect inner ends to ANT and GND on each module):
I tested those once and I can confirm jremington's range. It penetrated two walls and a good 100-200m of forest and shrubberies. I used either straight wire of appropriate length, or a spring antenna from Aliexpress, but certainly not more.
