RFID multiple tags?
i'm having trouble with writing code, i'm trying to self teach myself, but its not good well. have hacked bits of different code together,to make my alarm system project but i cant figure out how to add more then one RFID tag to the code. is it possible that someone can give us a hand trying to sort it thanks.
this is what have.
 Typical pin layout used:
               MFRC522      Arduino       Arduino
               Reader/PCD   Uno/101       Nano v3
   Signal      Pin          Pin           Pin
   RST/Reset   RST          9             D9      orange
   SPI SS      SDA(SS)      10            D10     yellow
   SPI MOSI    MOSI         11 / ICSP-4   D11     green
   SPI MISO    MISO         12 / ICSP-1   D12     blue
   SPI SCK     SCK          13 / ICSP-3   D13     purple
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
int RELAY = 8;
int REDLED = 7;
int GREENLED = 6;
int BUZZER = 5;
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("SHED DOOR.");
  pinMode (RELAY, OUTPUT);
  pinMode (REDLED, OUTPUT);
  pinMode (GREENLED, OUTPUT);
  pinMode (BUZZER, OUTPUT);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content = "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
    content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
    content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "85 A5 B0 56") //change here the UID of the card/cards that you want to give access
    Serial.println("Authorized access");
    Serial.println("Welcome Mr Hughes");
    digitalWrite (BUZZER, HIGH);
    digitalWrite (BUZZER, LOW);
    digitalWrite (RELAY, HIGH);
    digitalWrite (GREENLED, HIGH);
    delay(10000);
    digitalWrite (RELAY, LOW);
    digitalWrite (GREENLED, LOW);
  else   {
    Serial.println(" Access denied");
    digitalWrite (REDLED, HIGH);
    delay(3000);
    digitalWrite (REDLED, LOW);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
The line
Should look for all the cards you want to have access to your system. If this is just a few use a compound if statement here with the OR function ||
 if (content.substring(1) == "85 A5 B0 56" || content.substring(1) == "23 E5 B0 28" );
