Hello, everybody!
My rfid card have two values recorded in it. Each one is a number with 11 positions.
The exemple sketch "rfid_read_personal_data" show the correct values on the serial monitor, but I can't store these values in a variable.
Exemple of content in rfid card (as serial monitor shows):
Value 1:
00376754486
Value 2
00709081323
To show one of these values on serial monitor, the exemple sketch uses this:
byte buffer1[18];
block = 4;
len = 18;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
if (status != MFRC522::STATUS_OK) {
Serial.print(F("Authentication failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
status = mfrc522.MIFARE_Read(block, buffer1, &len);
Serial.print(F("Reading failed: "));
return;
for (uint8_t i = 0; i < 16; i++)
if (buffer1[i] != 32)
Serial.write(buffer1[i]);
How can I store each value in the respective variable? Char, string or int would be perfect to my use.
Thank you very mutch!
When you receive a character put it in an array of chars and increment the index to the array ready for the next character and put a '\0' in there to turn it into a C style string. Keep doing this until you get an end of data character, probably a '\r' or '\n'. Your data is now in the string. It could be copied to another string, compared to another string or converted to another data type if required
You didn't posted a complete sketch and from your description it is unclear to me
which lines of code print the 11-digit number?
Is it the
or is it the
It would be very helpful if you first would add some comment that is printed on the serial monitor too
and then post the copy&pasted characters that you receive in the serial-monitor
by addinng comment I mean something like this
Serial.print( F("content of buffer is#") );
Serial.println( F("#") );
So I just can guess but not know for sure that your output would look like this
content of buffer is#00376754486#
The leading "#" and the trailing "#" would clearly indicate what characters are printed
As you seem a newcomer I recommend using a library like PString or SafeString to work with strings
as you didn't posted your full sketch I can't compile the code-snippet
Which means that a type stays undiscovered
#include "SafeString.h" // my SafeString library from the Arduino library manager
const size_t maxStrLength = 18;
createSafeString(myRFIDStr, maxCmdLength + 1);
byte buffer1[maxStrLength];
block = 4;
len = 18;
return;
return;
myRFIDStr = "";
myRFIDStr += buffer1[i];
Serial.print( F("content of variable myRFIDStr is #") );
Serial.print(myRFIDStr);
best regards Stefan
