RFID RDM6300 doesn't work
i try to have the serial port print out"red,yellow or blue" when the rfid read a tag but i doesn't seem to work, can anyone help me?
The rfid is RDM6300 UART
This is the code
int readVal = 0; // individual character read from serial
unsigned int readData[10]; // data read from serial
int counter = -1; // counter to keep position in the buffer
char tagId[1]; // final tag ID converted to a
//////RFID///////
const int NUMBER_OF_TAGS = 27;
String tags[NUMBER_OF_TAGS] = {
//1do//
"0E0078F577",
"0E00791C23" ,
"0E007B55D7" ,
"0E00790AD5" ,
"0E007932D3",
"0E007B577E",
"0E0079476E",
"0E0079EE74",
"0E007956BF",
"0C002467F1" ,
//2vang//
"0E0079B9CC",
"0E002E1647",
"0E0079C305",
"0E007C6055",
"0C0028A5A2",
"0E002F6D7A",
"0E007BE683",
"0E0078CC9E",
"0E00793C9A",
///3xanh///
"0D002F32D1",
"0C0034389E",
"0E0031FD73",
"0E007C1EAB",
"0E002D77E7",
"0C00283412",
"0C00346C97",
"0E007BB1D8"
int types[NUMBER_OF_TAGS] = {
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3 };
void parseTag() {
int i;
for (i = 0; i < 10; ++i) {
tagId = readData*;*
* tagId[10] = 0;*
* void checktagcolor() {*
* String tagId = "";*
for (int i =0; i < NUMBER_OF_TAGS; ++i) {
_ if (tagId == tags*) {
if (types == 1) {
Serial.println("Red");
else if(types == 2) {
Serial.println("Yellow");
else if (types == 3) {
Serial.println("Blue");
void processTag() {
// convert id to a string*
* parseTag();*_
* // print it*
* printTag();*
* ////checkcolor////*
* checktagcolor();*
void printTag() {
* Serial.print("Tag value: ");*
* Serial.println(tagId);*
void clearSerial() {
* while (Serial.read() >= 0) {*
* ; // do nothing*
if (Serial.available() > 0) {
* // read the incoming byte:*
* readVal = Serial.read();*
* // a "2" signals the beginning of a tag*
* if (readVal == 2) {*
* counter = 0; // start reading*
* // a "3" signals the end of a tag*
* else if (readVal == 3) {*
* // process the tag we just read*
* processTag();*
* // clear serial to prevent multiple reads*
* clearSerial();*
* // reset reading state*
* counter = -1;*
* // if we are in the middle of reading a tag*
* else if (counter >= 0) {*
* // save valuee*
* readData[counter] = readVal;*
* // increment counter*
* ++counter;*
Did you write your code in italics? No, the forum has mangled the code, that is why we request you to post code using code tags. Read the how to use the forum sticky post and edit that first post so that it complies.
Need to explain more. Does you hardware setup work with the sample code for the RFID? If not how have you got it wired up? Schematic required.
