RFID readers and Processing
I'm working on a project that includes two Parallax RFID card readers (28140). These readers are at different locations, one on a construction site and one in a warehouse. The idea is that they 'read' incoming and outgoing assets and send them to a processing sketch that does something with it.
The problem is that i can't get the two separate arduinos unos with their RFID readers to connect to one single processing sketch. The arduinos are connected via serial ports to a laptop on which the processing sketch runs.
How ever i don't know how to get this to work...
This is the arduino code I use, I have a similar one for the other arduino and the reader.
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arduino by djmatic
// Modified 1-12-2015 to produce the correct tag number by M. Robertson
int  val = 0;
char code[10];
int bytesread = 0;
int i = 0;
int myNum[10];
unsigned long int multArray[] = {1, 1, 268435456, 16777216, 1048576,
                                 65536, 4096, 256, 16, 1
unsigned long int trueTag = 0;
int countYellowC = 0;
int countGreenC = 0;
int countRedC = 0;
  Serial.begin(2400);                          // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(2, OUTPUT);                          // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(2, LOW);                        // Activate the RFID reader
  if (Serial.available() > 0) {                // if data available from reader
    if ((val = Serial.read()) == 10) {         // check for header
      bytesread = 0;
      while (bytesread < 10) {                 // read 10 digit code
        if ( Serial.available() > 0) {
          val = Serial.read();
          if ((val == 10) || (val == 13)) {    // if header or stop bytes before the 10 digit reading
            break;                             // stop reading
          code[bytesread] = val;               // add the digit
          bytesread++;                         // ready to read next digit
      if (bytesread == 10) {                   // if 10 digit read is complete
        code[0] = 48;                          //Zero out the first two elements of the code array
        code[1] = 48;
        //Cycle through the code array and create int elements in myNum
        for (i = 0; i < 10; i++)
          if (code[i] == '0')                  //I am not a programmer, but this is the only way I could
            myNum[i] = 0;
          else if (code[i] == '1')             //find to convert elements of a char array to ints...
            myNum[i] = 1;
          else if (code[i] == '2')
            myNum[i] = 2;
          else if (code[i] == '3')
            myNum[i] = 3;
          else if (code[i] == '4')
            myNum[i] = 4;
          else if (code[i] == '5')
            myNum[i] = 5;
          else if (code[i] == '6')
            myNum[i] = 6;
          else if (code[i] == '7')
            myNum[i] = 7;
          else if (code[i] == '8')
            myNum[i] = 8;
          else if (code[i] == '9')
            myNum[i] = 9;
          else if (code[i] == 'A')
            myNum[i] = 10;
          else if (code[i] == 'B')
            myNum[i] = 11;
          else if (code[i] == 'C')
            myNum[i] = 12;
          else if (code[i] == 'D')
            myNum[i] = 13;
          else if (code[i] == 'E')
            myNum[i] = 14;
          else if (code[i] == 'F')
            myNum[i] = 15;
            myNum[i] = 9999;                       //Oops! an error
        //With trueTag initialized to 0, create the true tag number by summing trueTag with each element of the
        //integer myNum array multiplied by the corresponding element of the multArray.
          trueTag = trueTag + (myNum[i] * multArray[i]);
        if (trueTag == 3372093) {
          countYellowC++;
          if (countYellowC % 2 == 0) {
            Serial.print(3);
          else {
            Serial.print(2);
        else if (trueTag == 3375172) {
          countGreenC++;
          if (countGreenC % 2 == 0) {
            Serial.print(9);
          else {
            Serial.print(8);
        else if (trueTag == 3369475) {
          countRedC++;
          if (countRedC % 2 == 0) {
            Serial.print(6);
          else {
            Serial.print(5);
      bytesread = 0;
      trueTag = 0;                                 //Zero out trueTag for next iteration of the loop
      digitalWrite(2, HIGH);                       //deactivate the RFID reader for a moment so it will not flood
      delay(2500);                                 //wait for a bit
      digitalWrite(2, LOW);                        //Activate the RFID reader
this is the processing sketch I use:
import processing.serial.*;
Serial arduino1;
Serial arduino2;
void setup(){
String portName1 = Serial.list()[0];
  arduino1 = new Serial(this, portName1, 2400);
  String portName2 = Serial.list()[1];
  arduino2 = new Serial(this, portName2, 2400);
void draw() {
  if (arduino1.available() > 0) {  // If data is available,
    val = arduino1.readString();
  if (arduino2.available() > 0) {  // If data is available,
    val1 = arduino2.readString();}
print("arduino 1:",val, "   ");
  println("arduino 2:",val1);
