It can scan the right card and it will display the working message but as soon as it scans the wrong card. It will stop working. I am sure that everything is properly connected. Here is my code:
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define relay 2
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
int touchPin = 8;
unsigned long previousMillis = 0; // will store last time LED was updated
unsigned long tacc = 5000UL; // interval at which to blink (milliseconds)
boolean opened = false;
pinMode(touchPin, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
Serial.println("Approximate your card to the reader...");
int touchValue = digitalRead(touchPin);
if (touchValue == HIGH) {
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content = "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "23 09 EF D3" ) {
Serial.println("Authorized access");
digitalWrite(relay, LOW);
opened = true;
if (((unsigned long)(currentMillis - previousMillis) >= tacc) && (opened== true)) {
opened = false;
