Hi folks,
This is my first post here, relatively new to c++ and arduino, Over the past few months I've been building and designing a device to monitor the health of a population of red squirrels I look after.
The ultimate aim is to have a unit that measures and records (read datalogger!) the time, date, weight, temperature, humidity, microchip number - then logged onto an SD card and onto a 20x4 lcd screen.
So far I've managed to achieve all of the above, with the exception of reading the microchip number.
For simplicity we'll ignore all but the microchip problem!
Arduino uno R4
WL-134 RFID reader
connected to pin 0 (Rx) 5v and gnd,
I have tried several permutations of code (most from on here - Red_Car I believe), and whilst I do recieve some data in the serial monitor, it is not correct or correctly interperitable (as I understand it.)
#include <SoftwareSerial.h>
SoftwareSerial RFID(0, 1);
byte b;
byte buffer[30];
uint8_t idx;
boolean started = false;
byte XOR;
byte inverted;
uint64_t value;
Serial.begin (9600);
RFID.begin (9600);
String content = "";
while (RFID.available())
b = RFID.read();
if (b == 0x02) // Start byte
idx = 0;
started = true;
if (started) // Ignore anything received until we get a start byte.
buffer[idx++] = b;
if (b == 0x03) // End byte
started = false;
// Display the received data.
Serial.print("Received data: ");
for (int x = 0; x < idx; x++)
if (buffer[x] < 0x10)
Serial.print("0"); // Pad with leading 0
Serial.print (buffer[x], HEX);
Serial.print (" ");
Serial.println("");
// Check we received the message ok. XOR checksum on bytes 01-26 should match byte 27.
XOR = buffer[1];
for (int x = 2; x <= 26; x++)
XOR ^= buffer[x];
Serial.print("Calculated checksum: ");
Serial.print(XOR, HEX);
if (XOR == buffer[27])
Serial.println(" (Correct)");
Serial.println(" (Error)");
// Check the inverted XOR checksum
inverted = ~XOR;
Serial.print("Inverted checksum: ");
Serial.print(inverted, HEX);
if (inverted == buffer[28])
// Extract the card number from bytes 01 (LSB) - 10 (MSB).
value = 0;
for (int x = 10; x >= 1; x--)
if(buffer[x] <= '9')
value = (value<<4) + buffer[x] - '0';
value = (value<<4) + buffer[x] - '7';
Serial.print("Card number: ");
Serial.println(value);
// Extract the country number from bytes 11 (LSB) - 14 (MSB).
value = 0;
for (int x = 14; x >= 11; x--)
Serial.print("Country number: ");
// Extract the Data Block from byte 15.
Serial.print("Data block: ");
Serial.println(buffer[15] - '0');
// Extract the Animal Flag from byte 16.
Serial.print("Animal flag: ");
Serial.println(buffer[16] - '0');
Serial.println("\r");
In the serial plotter I recieve
"Received data: 02 FD 03
Calculated checksum: 8B (Error)
Inverted checksum: 74 (Error)
Card number: 158002015478
Country number: 900
Data block: 1
Animal flag: 1"
The microchip should read as - 900158002016106
I have read a lot of the posts on here about RFID readers, and I'm loathed to ask for help but I've only succeeded in confusing myself!
Any help greatly appreciated.
I hope I've got things formatted correctly!
Ben
