Rfid
`#include <SPI.h>’
#include <MFRC522.h>
#include <Servo.h>
Servo myservo;
int potpin = 0;
int val;
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
SPI.begin();
mfrc522.PCD_Init();
Serial.println(“Arduino RFID lock”);
Serial.println("");
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
myservo.attach(3);
myservo.write( 0 );
void loop(){
val = analogRead(potpin);
if ( !mfrc522.PICC_IsNewCardPresent() ){
return;
if ( !mfrc522.PICC_ReadCardSerial() ) {
return;
String content= “”;
byte letter;
for( byte i = 0; i < mfrc522.uid.size; i++ ){
content.concat(String(mfrc522.uid.uidByte*, HEX));*
if( i < mfrc522.uid.size-1 ) content+="-";
content.toUpperCase();
Serial.println(“UID tag :’” + content + “’”);
Serial.print(content);
if( content== “55-33-2C-83”)
val = map(val, 0, 1023, 0, 150);
else if( content==“91-2B-D2-2F”)
  • val = map (val, 0, 1023, 0, 60);*
    myservo.write(val);
    delay(15);
    This is my code .i want to do my servo to rotate 0to180 when rfid scan specific tag.and rotate 0 to 60 when scan another tag.
    But the issue is .i want to change the servo pos when rfid scan once .
    The above program runs when the rfid scan the tag after removing it didn’t work. Pls help by providing some codes.
Please read read this before posting a programming question and post your code in code tags to stop it turning into italics
