I am now able to upload without Error and the boards start up and the RFM69HCW intit and the "setFrequency" does not fail but when it sends the data it is not sending, or the server is not receiving. Here is the sketch's I am using:
Server:
#include <SPI.h>
#include <RH_RF69.h>
RH_RF69 rf69(D6, D7);
while (!Serial)
if (!rf69.init())
Serial.println("init failed");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
// No encryption
if (!rf69.setFrequency(915.0))
Serial.println("setFrequency failed");
// If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
// ishighpowermodule flag set like this:
rf69.setTxPower(14, true);
// The encryption key has to be the same as the one in the client
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
rf69.setEncryptionKey(key);
#if 0
// For compat with RFM69 Struct_send
rf69.setModemConfig(RH_RF69::GFSK_Rb250Fd250);
rf69.setPreambleLength(3);
uint8_t syncwords[] = { 0x2d, 0x64 };
rf69.setSyncWords(syncwords, sizeof(syncwords));
rf69.setEncryptionKey((uint8_t*)"thisIsEncryptKey");
#endif
if (rf69.available())
// Should be a message for us now
uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf69.recv(buf, &len))
// RH_RF69::printBuffer("request: ", buf, len);
Serial.print("got request: ");
Serial.println((char*)buf);
// Serial.print("RSSI: ");
// Serial.println(rf69.lastRssi(), DEC);
// Send a reply
uint8_t data[] = "And hello back to you";
rf69.send(data, sizeof(data));
rf69.waitPacketSent();
Serial.println("Sent a reply");
Serial.println("recv failed");
Client:
#include <SPI.h>
// Singleton instance of the radio driver
//RH_RF69 rf69;
//RH_RF69 rf69(15, 16); // For RF69 on PJRC breakout board with Teensy 3.1
//RH_RF69 rf69(4, 2); // For MoteinoMEGA https://lowpowerlab.com/shop/moteinomega
//RH_RF69 rf69(8, 7); // Adafruit Feather 32u4
while (!Serial)
if (!rf69.init())
// No encryption
// The encryption key has to be the same as the one in the server
Serial.println("Sending to rf69_server");
// Send a message to rf69_server
uint8_t data[] = "Hello World!";
delay(1600);
// Now wait for a reply
if (rf69.waitAvailableTimeout(500))
// Should be a reply message for us now
Serial.print("got reply: ");
Serial.println("No reply, is rf69_server running?");
delay(400);
