I am relativity new to the world of digital electronics. I am trying to learn as fast as possible because I am about to be teaching it to High School Kids in a little more than a month. I am working on a project to use a push button to switch between multiple RGB LED Strip programs. I have pulled the majority of the code from different places as you will see in the notes. I had the Edge detection working great with a simple LED hooked up to pin 13, I was able to get it to flash at different rates, stay on, and then turn off. I can also get the RGB codes to work on their own. When I inserted the RGB code into the Edge Detection program it gets stuck in the first program. The button detection program does not recognize the push button after the first press. I have been messing with the program for hours now but I can not figure out what I am doing wrong. Please help me determine the problem.
Thanks,
Brian
Using a push button to switch between 3 differnt RGB Codes and turning the system off.
This code is compiled from two sources. First the edge detection program was written by Tom Igoe and can be found at http://arduino.cc/en/Tutorial/ButtonStateChange
Secondly, the RGB color code is found at http://www.ladyada.net/products/rgbledstrip/. The Schemetic can be found there as well.
The circuit:
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
* 3 STP16NF06 MOSFETs are used.
* MOSFET 1(Green) G-Digital Pin6 D-Green Input on RGB Strip S-Ground
* MOSFET 2(Red) G-Digital Pin5 D-Red Input on RGB Strip S-Ground
* MOSFET 3(Blue) G-Digital Pin3 D-Blue Input on RGB Strip S-Ground
*LED Strip 12v source is attached to the 9v Arduino Supply
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
#define REDPIN 5
#define GREENPIN 6
#define BLUEPIN 3
int r, g, b;
#define FADESPEED 5 // make this higher to slow down
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
//off
if (buttonPushCounter == 0) {
digitalWrite(ledPin, LOW);
//color fade
if (buttonPushCounter==1){
// fade from blue to violet
for (r = 0; r < 256; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(BLUEPIN, b);
delay(FADESPEED);
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
//Pink to Orange Strobe
if (buttonPushCounter==2){
//pink
analogWrite(REDPIN, 255);
analogWrite(BLUEPIN, 80);
analogWrite(GREENPIN,15);
delay(250);
//orange
analogWrite(BLUEPIN, 0);
analogWrite(GREENPIN,35);
delay(250);
if (buttonPushCounter==3){
//white-on
analogWrite(BLUEPIN, 255);
analogWrite(GREENPIN,255);
delay(100);
//off
analogWrite(REDPIN, 0);
analogWrite(GREENPIN,0);
delay(100);
if (buttonPushCounter==4){
analogWrite(GREENPIN,0);;
I don't get any error in the debug area. The program loads fine. When I turn Serial Monitor on and press the push button it starts the program and registers that the button has been pressed (in the serial monitor.) When I let the push button go the serial monitor should read "off" but it does not. If I run the attached code it works fine.
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
else {
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
digitalWrite(ledPin, HIGH);
delay (100);
digitalWrite (ledPin,LOW);
delay(200);
loop;
buttonPushCounter = 0;}
AWOL:
You have lots of serial debug prints in that sketch.
What do they tell you, and us?
Hint: post the output from the serial monitor.
OK. If I am running the edge detection by itself this is what I get in the serial monitor.
on
number of button pushes: 1
off
on
number of button pushes: 2
off
on
number of button pushes: 3
off
on
off
If I run the serial monitor with the RGB Code this is what I get...
on
So that is telling me that once the Color Swirl program starts running the Arduino stops checking Digital I/O 2. So how can I make the microcontroller check the IO again?
After hitting the button the first time, are you waiting for all the fading to occur before you expect to see "off"?
The way your program is written, all of your fades will have to occur before the buttonPin is read again. ie. gets back to the start of the loop)
If you expect to be able to let go of the button and instantly the serial displays "off", then you will need to change your program completely.
carlito:
Ok that makes since. Can the Arduino run two parts of a program simultaneously? If so do you know of a good example?
There are a couple of ways that spring to mind to achieve what you want. One dirty way is simply to scatter reads of the button through the rest of your code & break out of your fading loops if it's changed again - not recommended. The other way is to use a state variable to keep track of what led function you're performing and do the next step of it each time round the loop if it is time. That way you're using millis to tell you when next to act and checking the button very frequently. Search for state machine in the forums to find examples. You have the classic issue that your use of delay is making your code unresponsive to inputs. Therefore, look at the blink without delay example - it'll show you how to use millis.
Your application will be a little complex to build as your first state machine - consider just making it flip between two or three states - your fades would be fine. Just remember that while you're fading, you change r (for example) by one each time it's time to do so so it will only change zero or one times on each iteration of loop.
Finally, you have some braces misplaced in your code that mean that the pink orange strobe will never happen - the check for buttonPushCounter==2 is inside the check for buttonPushCounter==1, so it can't be true. Consider putting some of this code into their own functions to shorten loop and make such things easier to see.
Ash4004:
That sounds pretty extraordinary. If you don't know the subject yourself, then how can you be qualified to teach it?
I am trying to update my code to include State Variables. I am trying to change the way it works slightly. I want to push the button between 1 and 3 times within 2000ms to select different LED programs. After the 2000ms has past I want the push button to turn the system off if it is pushed again. It Compiles and loads, but the Serial Monitor repeats One push... example
on
on
on
on
Here is the code.
const int ledPin=11;
const int pushButton=2;
//variable
int ledState=LOW;
long previousMillis=0; //will store the lasttime the Button was pushed
long interval=2000;
int pushCounter = 0;
int buttonState= 0;
int lastButtonState=0;
void setup(){
pinMode (ledPin, OUTPUT);
pinMode (pushButton, INPUT);
pinMode (pushButton, 0);
void loop ()
buttonState=digitalRead (pushButton);
unsigned long currentMillis=millis();
if (buttonState!= lastButtonState && currentMillis-previousMillis<interval)
if (buttonState == HIGH)//pushbuttion went from off to on
previousMillis=currentMillis; //reset previousMillis
pushCounter++; //increase counter
Serial.println ("on");
Serial.println(pushCounter);
else {
if (pushCounter ==1) //fade w/o delay
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
if (pushCounter ==2) //slow blink (1000ms)
int ledState = LOW; // ledState used to set the LED
long previousSlowMillis = 0; // will store last time LED was updated
long slowInterval = 1000; // interval at which to blink (milliseconds)
if(currentMillis - previousSlowMillis > slowInterval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
if (pushCounter ==3) //fast blink (100ms)
long previousFastMillis = 0; // will store last time LED was updated
long fastInterval = 100; // interval at which to blink (milliseconds)
if(currentMillis - previousFastMillis > fastInterval) {
ledState = HIGH;
ledState = LOW;
if (pushCounter=4)
pushCounter=0;
if (buttonState!= lastButtonState && currentMillis-previousMillis>interval)
pushCounter=0;
I have a pull down button connected to IO 2. I have The pushbutton at 0 to tell the program that it is off. Now that I think of it more though, the pull down is sending 0v. So it already knows that it is off.
The second pinMode call is wrong it should be removed.
If the button is pulling down then you need either a pull up resistor or you need to enable the internal pull up. I don't see this being enabled in your code.
