RGB LED matrix control
I have recieved a sparkfun rgb led matrix as a gift :slight_smile:
My question is how do i control it?
Well, judging by the datasheet... well it required a 20MB chinese font download to display.
There are 32 pins underneath. For a normal array of LEDs (just a single colour), you can multiplex then - so 64 LEDs would be 2 x sqrt(64), or 16. For this tri-colour LED matrix, there are 4 pins per LED, so 4 x sqrt(64), or 32.
I would assume three sets of 8 pins would be rows of anodes, and the last 8 pins would be columns of grounds.
Ah, in their diagram, they have rows for the cathodes, and columns of the anodes.
Could I use Max7219's to control it? i have two right now as samples, so i want to use them in something. Controlling just R & G will be fine for me right now :slight_smile:
No, your matrix uses common-anode Led's, the MAX7219 works only for common-cathode Led's
Eberhard
I guess the ever so famous TLC5940 would be handy here as well. :slight_smile:
Eberhard
I'm not so sure it's a common anode. From Sparkfun's description . . .
"Description: Triple Color LED Matrix! This large matrix has 64 Red, 64 Green, and 64 Blue individual LEDs built into one common cathode housing. It's a monster to control, but just imagine what kind of colors you could produce by mixing!"
Sometimes the data sheets for these show both models - easy enough to confirm though.
If it is common-cathode (and I think it is) and you want to drive only 2 colors (without fading individual led colors) 2 MAX7219's should work.
There are several threads on that here. Here is one:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206907547
(and after I promised myself I wouldn't get involved! :-X)
http://www.datasheetcatalog.org/datasheet/fairchild/GMA3688C.pdf
is the datasheet, :cry: its not a RGB one just bicolor, guess i should look at these things before i post ;D
its common anode, not CC like it says in Sheet
Pin :
1 Anode row 8 24 Anode row 1
2 Anode row 7 23 Anode row 2
3 Anode row 6 22 Anode row 3
4 Anode row 5 21 Anode row 4
5 Cathode col. 1 G 20 Cathode col. 1 R
6 Cathode col. 2 G 19 Cathode col. 2 R
7 Cathode col. 3 G 18 Cathode col. 3 R
8 Cathode col. 4 G 17 Cathode col. 4 R
9 Cathode col. 5 G 16 Cathode col. 5 R
10 Cathode col. 6 G 15 Cathode col. 6 R
11 Cathode col. 7 G 14 Cathode col. 7 R
12 Cathode col. 8 G 13 Cathode col. 8 R
Does calling a matrix common anode or common cathode really mean anything? Seems like its both - the rows are common anode, the columns are common cathode.
it makes a difference when you want to controll it
Eventually i will want it to Scroll Messages across it
And Play Pong :smiley:
i guess i could do it with 74hc595's
LED Matrix Controller
With only 595's? How is that possible?
Dont u need both anode & cathode?
Im asking because ive been trying to figure out this myself, how to use only the 595's for this, but i still dont know really.
in the link hes using three 74hc595's to control a common cathode matrix i could adjust it to common anode sigh
ah right, ill study that matrix a bit more then. most interesting... i would love to use the 595's, they are easy enough and cheap!
I thought we established that you had a common cathode display?
BTW the link to the last data sheet doesnt match what I know of Sparkfun matrixes.
If you indeed have a 2 color matrix - "medium" you have -
and the data sheet is
(which may have the same pin outs as your link.)
If the above is true, you can use the 2 MAX7219 chips you say you have. (They don't need to be the MAX7221 & I don't know why - but they work.)
I have used this setup for 2 colors on the matrix and scrolling messages. However I do the scrolling with one color at a time - only because of the complexity of programming in the 2 colors. I also have a two color "bouncing ball" thingy that might help with pong. (The code was somewhere on this forum.)
I can't speak at all for the 595's but if you want to investigate the RG w/ the Max, you can start here:
i know, i just thought that it was a sparkfun one, the datasheet that i gave you was the right one.
which one would be easier to program ? max7219 or 74hc595?
BTW i am eventually going to want to make a sheild out of this whic would be the smallest one?
I gotta say, that 595 matrix had me curious.. seems that guy is using a 595 for the GND/row as well, how is that even possible?
As its a powersourcing driver i mean.. judging from the pictures he is using 1k resitors on the 595 chip that controls the GND.. one can say im a bit puzzled. :slight_smile:
he uses NPN transistors, when the 595 sources current it turns on the transistor pulling the pin to GND. Thats all he does
Ah, thank you! I could never have figured that out.
From what i can understand, he is using 1k resistors, and BC848B NPN transistors, is that right?
Yes That is correct
