All,
I have searched the forums and online, but I can't seem to find exactly the help that I need. I am wanting to build where I can change 8 colors of an RGB LED using ONE push button. Every time I push the one button, I want it to change more than just red, green, and blue. I would like magenta, yellow, white, etc... I would also like it to debounce to ensure accuracy. I think I saw something about using a library, but I would like to try and avoid it if possible. I guess, how can I create a method or function that stores the different analog colors of the RGB (80,0,80)? I really appreciate the support. Below is my code, but it doesn't work so if someone could tinker then that would be great. Or maybe, it is just not possible outside of the main 3 colors.
// First we'll set up constants for the pin numbers.
// pushbutton pin
const int buttonPin = 3;
//RGB LED pins
const int redPin = 11;
const int greenPin = 10;
const int bluePin = 9;
//create a variable to store a counter and set it to 0
int counter = 0;
long time = 0; // the last time the output pin was toggled
long debounce = 200;
// Set up the pushbutton pins to be an input:
pinMode(buttonPin, INPUT);
// Set up the RGB pins to be an outputs:
pinMode(redPin, OUTPUT);
pinMode(greenPin,OUTPUT);
pinMode(bluePin,OUTPUT);
// local variable to hold the pushbutton states
int buttonState;
//read the digital state of buttonPin with digitalRead() function and store the //value in buttonState variable
buttonState = digitalRead(buttonPin);
setColor(255, 0, 0); // red
setColor(0, 255, 0); // green
setColor(0, 0, 255); // blue
setColor(255, 255, 0); // yellow
setColor(80, 0, 80); // purple
setColor(0, 255, 255); // aqua
//if the button is pressed increment counter and wait a tiny bit to give us some
//time to release the button
if (buttonState == LOW && millis() - time > debounce) // light the LED
counter++;
delay(150);
//use the if satement to check the value of counter. If counter is equal to 0 all
//pins are off
if(counter == 0)
digitalWrite(redPin,LOW);
digitalWrite(greenPin,LOW);
digitalWrite(bluePin,LOW);
//else if counter is equal to 1, redPin is HIGH
else if(counter == 1)
digitalWrite(redPin,HIGH);
//else if counter is equal to 2 greenPin is HIGH
else if(counter ==2)
digitalWrite(greenPin,HIGH);
//else if counter is equal to 3 bluePin is HIGH
else if(counter ==3)
digitalWrite(bluePin,HIGH);
//else if counter is equal to 4 whitePin is HIGH
else if(counter ==4)
//else reset the counter to 0 (which turns all pins off)
counter =0;
time = millis();
void setColor(int redValue, int greenValue, int blueValue)
analogWrite(redPin, redValue);
analogWrite(greenPin, greenValue);
analogWrite(bluePin, blueValue);
