RGBWW LED change on or between specified time
Hi there!
I'm new on this forum so if there are any things that needs to be in a topic please let me know.
I have written a code for my RGBWW LED strip, for now just only the RGB colors to test. I would like to have RGB values between a timeset.
Example;
  • before <0700 in the morning all leds are off.
  • between 0700 && 1200 sunrise
  • between 1200 && 1800 daylight
  • between 1800 && 2200 evening
  • after 2100 all leds are off
I am only not able to create an if else statement which I should use in PHP or C#
In the attachment my code because it's to big to post it here, if you have any questions please let me know.
sketch_LEDTemp_v1.3.ino.ino (8.42 KB)
A big part of why it's so big, is that you haven't factored the code much (there is a lot of repetition of code patterns). Usually, that means that you have not structured your data and program in a hierarchical, top down way. You should use arrays, structs for data - functions and definitions for code - to greatly reduce the size of your code. This also has the benefit of making it easier to troubleshoot and maintain.
If you do this, implementing a new requirement such as you've posted above, will also be much, much easier. Unfortunately, I think you will find that most people will be reluctant to help you because of the code verbosity.
"I am only not able to create an if else statement which I should use in PHP or C#"
I don't understand what you mean by this statement above.
It looks like your making a color clock with temp. Am I correct? I on'y ask because I've recently done one of these myself for a friend. And, if I'm correct you want to map time of day to colors? Can you describe what you are looking for a little more, in human, not code?
-jim lee
jimLee:
-jim lee
Hi Jim,
The statement above, is that I know how to handle with an if else statement. But for an Arduino it doesn't make any sense.
Yeah that's true, in the best case just only change RGB colors in a time range. the temp is just another thing.
What I really really want is the following;
3 or more time blocks which have set their own colors for the LEDs. Before, between or after a time range like below;
  • before 07.00in the morning all leds are off.
  • between 07.00 && 12.00 sunrise
  • between 12.00 && 18.00 daylight
  • between 18.00 && 22.00 evening
  • after 21.00 all leds are off
Again, the value of the temperature is not important for the first case.
Thanks in advance!
Again, this makes no sense. Arduio, using c++ uses if then else just like everything else.
What I did, awhile ago, is create a multi color mapper. You can, with this, map time to a colors. You are welcome to try it. But, many people have trouble understanding my stuff.
If you like : My Arduino library folder The folder inside this you want is LC_baseTools That should contain all the bits you need to use it. There is a wiki attached and the library you want in there is colorObj.
Good luck
-jim lee
jimLee:
Good luck
-jim lee
Hi Jim,
I really would like to try this. but in my case I would like to use something like an if else statement between 2 times. This because in the code which is in the topic attached I only have colors. But the next step is to control a relay for a H2O pump.
Like this example below;
    if (displayTime < (0600)) {
    Serial.println("Night");
    red = nightR;
    green = nightG;
    blue = nightB;
    else if (displayTime > (0700) && displayTime < (1100)) {
    Serial.println("Sunset");
    red = SSR;
    green = SSG;
    blue = SSB;
    else if (displayTime > (1200) && displayTime < (1800)) {
    Serial.println("Day");
    red = dayR;
    green = dayG;
    blue = dayB;
    else if (displayTime > (1800) && displayTime < (2000)) {
    Serial.println("Sunrise");
    red = SSR;
    green = SSG;
    blue = SSG;
    else if (displayTime > (2000) && displayTime < (2100)) {
    Serial.println("Evening");
    red = SSR;
    green = SSG;
    blue = SSG;
    else {
    red = nightR;
    green = nightG;
    blue = nightB;
Thanks!
