[Risolto] [Wifi Shield] WL_IDLE_STATUS was not declared in this scope
Mi è appena arrivata la Wifi Shield e per fare un primo test (dopo averla inserita nella mia Arduino Uno rev3) ho provato ad eseguire il seguente sketch copiato/incollato da qui: http://arduino.cc/en/Guide/ArduinoWiFiShield#toc1
ma ottengo il seguente errore: "WL_IDLE_STATUS was not declared in this scope".
Ecco il codice in questione (...stampa le reti wifi rilevate):
#include <SPI.h>
#include <WiFi.h>
   // initialize serial and wait for the port to open:
   while(!Serial) ;
   // attempt to connect using WEP encryption:
   Serial.println("Initializing Wifi...");
   printMacAddress();
   // scan for existing networks:
   Serial.println("Scanning available networks...");
   listNetworks();
   delay(10000);
   listNetworks();
void printMacAddress() {
   // the MAC address of your Wifi shield
   byte mac[6];
   // print your MAC address:
   WiFi.macAddress(mac);
   Serial.print("MAC: ");
   Serial.print(mac[5],HEX);
   Serial.print(":");
   Serial.print(mac[4],HEX);
   Serial.print(":");
   Serial.print(mac[3],HEX);
   Serial.print(":");
   Serial.print(mac[2],HEX);
   Serial.print(":");
   Serial.print(mac[1],HEX);
   Serial.print(":");
   Serial.println(mac[0],HEX);
void listNetworks() {
   // scan for nearby networks:
   Serial.println("** Scan Networks **");
   byte numSsid = WiFi.scanNetworks();
   // print the list of networks seen:
   Serial.print("number of available networks:");
   Serial.println(numSsid);
   // print the network number and name for each network found:
   for (int thisNet = 0; thisNet<numSsid; thisNet++) {
     Serial.print(thisNet);
     Serial.print(") ");
     Serial.print(WiFi.SSID(thisNet));
     Serial.print("\tSignal: ");
     Serial.print(WiFi.RSSI(thisNet));
     Serial.print(" dBm");
     Serial.print("\tEncryption: ");
     Serial.println(WiFi.encryptionType(thisNet));
Ho già scaricato la Wifi Shield Library da questo link:
http://arduino.cc/en/uploads/Main/WiFiShield_library.zip
e posizionato la cartella WiFi in .../Arduino/library/
e non riesco a capire come mai ottengo quell'errore, chi sarebbe così gentile da aiutarmi?
Su IDE 1.0.2 con Win7 compila perfettamente.
Se è la shield ufficiale non c'è bisogno di aggiungere nessuna libreria.
Scarica il nuovo IDE --> http://arduino.cc/en/Main/Software
Ciao,
anche su ide 1.0.1 compila senza problemi, as is
Ho scaricato la versione 1.0.2 dell'IDE e ora compila! :astonished:
Grazie mille ragazzi per le risposte, veloci ed efficaci! :slight_smile:
Bene, buon WiFi con Arduino. :grin:
