RN42 connected to PC, nothing in Tera Term
Hey guys!
I´m struggling with this second day, searched all the Google, I´m desperate.
I´m trying to send a key stroke on a pushButton press to RN42 and as a result do display this in Tera Term. It may sound like a very easy thing to do, but I´m not sure where the problem is.
Basically, I am aware of how to set it up, using SoftwareSerial library would like to send the stroke and receive it on a PC. Indicator LED blinks, also TX LED on Arduino and even LED on RN42 blinks, but no data are displayed. I flashed the HID soft from RN42 to HC05...not sure if this may be related. Here´s the sketch
 BT communication test
#include <SoftwareSerial.h>
int bluetoothTx = 2;  // TX-O pin of bluetooth mate, Arduino D2
int bluetoothRx = 3;  // RX-I pin of bluetooth mate, Arduino D3
int inPin = 12;     // the number of the pushbutton pin
int ledPin = 13; // choose the pin for the LED
int val = 0;         // variable for reading the pushbutton status
//for tests
byte message[] = {0xAA, 0xBB, 0x06, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x03 };
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
   Serial.begin(9600);  // Begin the serial monitor at 9600bps
  bluetooth.begin(9600);
delay(50);
bluetooth.print("$$");
delay(50);
bluetooth.print("SN,Vlktch zmena\r\n");
delay(50);
bluetooth.print("S~,6\r\n");
delay(600);
bluetooth.print("SH,0000\r\n");
delay(2000);
bluetooth.print("R,1\r\n");
delay(400);
    pinMode(ledPin, OUTPUT);  // declare LED as output
  pinMode(inPin, INPUT);    // declare pushbutton as input
  Serial.println("Serial ready, hello world!");
   Serial.println("RN42 configured");
  Serial.println("BT Serial ready");
   val = digitalRead(inPin);  // read input value of pushButton
  if (val == LOW) {
    digitalWrite(ledPin, LOW);  // turn LED OFF
   delay(100);
    digitalWrite(ledPin, HIGH);  // on push turn LED ON
   Serial.println("0xFD, 0x03, 0x03, 0x80, 0x00"); //once pressed, content displayed in Serial, should be taken to the BT console of Teraterm(not working)
       //Serial.write(message, sizeof(message)); message above, works
    bluetooth.print("test"); //print test not working
    bluetooth.write("test");//write test not working
    delay(300);
  if(bluetooth.available())  // If the bluetooth sent any characters
    // Send any characters the bluetooth prints to the serial monitor
    Serial.print((char)bluetooth.read());
  if(Serial.available())  // If stuff was typed in the serial monitor
      // Send any characters the Serial monitor prints to the bluetooth
I´ll be very happy for all the suggestions!
Mike
