Пroblem - incorrect reading of an SSI absolute encoder
Hello!
I have a problem with reading data from the SSI absolute encoder. I have an ATM60-A1A12x12 encoder and connected it to an Arduino Uno using a max490 module rs422 to TTL.
ATM60-A1A12x12
My connections are:
A and B (max490)to D+ and D- (encoder)
Y and Z (max490)to clock+ and clock- (encoder)
RX(max490) to pin5 (Arduino)
TX(max490) to pin6 (Arduino)
I use this code that I found on the forum, but I only get the same number that does not change - 359.91
Please advice and help how to solve the problem!
const int CLOCK_PIN = 5;
const int DATA_PIN = 6;
const int BIT_COUNT = 25;
  //setup our pins
  pinMode(DATA_PIN, INPUT);
  pinMode(CLOCK_PIN, OUTPUT);
  //give some default values
  digitalWrite(CLOCK_PIN, HIGH);
  float reading = readPosition();
  if (reading >= -0.5) {
      Serial.print("Reading: ");
       Serial.println(reading,2);
//read the current angular position
float readPosition() {
  // Read the same position data twice to check for errors
  unsigned long sample1 = shiftIn(DATA_PIN, CLOCK_PIN, BIT_COUNT);
  unsigned long sample2 = shiftIn(DATA_PIN, CLOCK_PIN, BIT_COUNT);
  delayMicroseconds(25);  // Clock mus be high for 20 microseconds before a new sample can be taken
  if (sample1 != sample2)
    return -1.0;
  return ((sample1 & 0x0FFF) * 360UL) / 4096.0;
//read in a byte of data from the digital input of the board.
unsigned long shiftIn(const int data_pin, const int clock_pin, const int bit_count) {
  unsigned long data = 0;
  for (int i=0; i<bit_count; i++) {
    data <<= 1;
    digitalWrite(clock_pin,LOW);
    delayMicroseconds(1);
    digitalWrite(clock_pin,HIGH);
    data |= digitalRead(data_pin);
  return data;
