Hello, i need help for program: Grove Ultrasonic Ranger V2.0. My problem is I can not program the sensor when there is an obstacle to 50cm and must push it on. I have only succeeded with the simple HC-SR04:
#define trigPin 12 //je défini les broches du capteur
#define echoPin 13
int IN1=3; //je déclare une variable de type int appelée IN1 et valant 3
int IN2=4;
int ENA=5;
int us;
int IN3=6;
int IN4=7;
int ENB=8;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
pinMode(echoPin, INPUT);
us = 40 ;
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(IN3,OUTPUT);
pinMode(IN4,OUTPUT);
pinMode(ENB,OUTPUT);
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(2);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;// convertir en cm
if (distance >90) //si distance supérieur à 90 cm, robot tourne sur lui-même
analogWrite(ENA,180);//Tourne le robot sur lui même
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
digitalWrite(IN3,HIGH);
digitalWrite(IN4,LOW);
analogWrite(ENB,180);
else //détecte l'obstacle il avance
digitalWrite(ENA,HIGH);//avance
digitalWrite(IN3,LOW);//avance
digitalWrite(IN4,HIGH);
digitalWrite(ENB,HIGH);
thank for help
