First off, I'm pretty much entirely a newbie at the Arduino, microcontrollers in general, and C in general. But I'm quite good at messing around and figuring things out.
Anyway, I've posted before on this topic, but since then I have been first very busy, then Windowsless, then computerless, then busy... and so on. Finally getting around to working a bit with it. Basically I want to get my TI83+ calculator to talk to my Arduino, and vice versa. I have managed to get it to work, but I want to package it into an interrupt-driven library so I can (for example) run bitlash over the link. What's the easiest way to do this, do you think?
void sendByte(byte toSend){
byte b1 = 0;
int pin0 = 6;
int pin1 = 7;
for ( b1 =0;b1<=7;b1++){
if(toSend & 1){
pinMode(pin0,OUTPUT);
digitalWrite(pin0,LOW);
while(digitalRead(pin1)==1) {}
pinMode(pin1,INPUT);
pinMode(pin0,INPUT);
while(digitalRead(pin1)==0) {}
}else{
pinMode(pin1,OUTPUT);
digitalWrite(pin1,LOW);
while(digitalRead(pin0)==1) {}
while(digitalRead(pin0)==0) {}
toSend = toSend>>1;
// delayMicroseconds(188);
byte getByte(void){
byte out = 0;
int bit;
int pin0 = 6;
int pin1 = 7;
for(bit=0; bit<8; bit++) {
while((digitalRead(pin0) == 1) && (digitalRead(pin1) == 1)){}
if( digitalRead(pin0) == LOW ){
while( digitalRead(pin0) == LOW ) {}
out = (out >> 1) | 0x80;
}else{
while( digitalRead(pin1) == LOW ) {}
out = out >> 1;
return out;
