Hi All,
I got this rotary encoder and was wondering how I should connect it to my Arduino.
It has 4 wires, +, -, 01 and 02.
I tried to find information from the manufacturer, but not luck.
Any info helps.
Hi All,
Any info helps.
Do you have a part number? web link?
I would suspect it works like this
I got it from here: ROTARY ENCODER, OPTICAL W/100 SLOTS DISK 5V TTL
But it is the same as these two other links:
https://www.aliexpress.com/item/4000104861972.html
I was looking for something that shows if I need to put resistors in the circuit or a diagram.
Update.
So I connected it like this:
5V
GND
01 > 02 (INPUT)
02 > 03 (INPUT)
I am getting the reading fine (besides the fact that I didn't find the correct angle for this disc to work properly yet). However, I am concerned that I should add resistors somewhere in the circuit to protect the encoder and the board.
Should I really worry about it?
Thank you
