I am currently in a low level engineering course and have to build a device that measures angle and outputs it on a screen. I was looking a the grove rotary sensor and after some research I kind of get the idea behind doing it but i still really don't know what I am doing. So far I understand I need the following:
Base shield
rotary sensor
led screen
power supply
Not sure if thats everything that I need, and I am not really sure how to build it.
Another thing is when reading the introduction to the base shield it said when connecting it to the computer to add code that u should connect a temperature sensor. Why is this necessary?
I'm sure that someone, sooner or later, will recommend that you get an Arduino, too.
No idea what you are talking about. Post a link to the "base shield" you are talking about.
The photo and code in section one is just to illustrate one device, and the code to interact with it. You don't need a temperature sensor unless you want one.
I don't think that shield will even be all that useful to you. It would not be one of my first purchases.
What are you trying to measure the angle of? Something that you can attach a sensor to, like a rotary encoder, or something that moves, like a game controller? That would determine the type of sensor that you need.
So essentially I have to make an electric goniometer which is used in physical therapy to measure the range of motion of a joint by aligning it with an arm or another body part
mrw0816:
Is there some reason not to use a rotary potentiometer as the angular sensor? If that's an option it would be the most obvious approach.
PeterH:
Please elaborate lol, because i really dont know to much of what I am doing but i believe the grove rotary sensor that i was looking at was a potentiometer
A conventional rotary pot has a housing with a spindle sticking out. The spindle turns relative to the house. Attach the housing to one side of the joint and attach the spindle to the other, so that they move relative to each other as the joint flexes.
Imagine something like two 12" rulers connected by a pivot at one end. Arrange to mount that on the joint so that the pivot lines up with the center of movement of the joint. Then attach the pot housing and shaft to the two rulers so that as the two rulers move relative to each other they rotate the pot.
