and use the ouput on pin nine to drive the DAC using this code from http://hacking.majenko.co.uk/MCPDAC
to give us better resolution which would be feed into an non inverting amplifer to achive a 0 -10v signal could anyone give us some tips on how to code this as im very green cheers in advance
Rotory encoder sketch
int brightness = 0; // how bright the LED is, start at half brightness
int fadeAmount = 5; // how many points to fade the LED by
unsigned long currentTime;
unsigned long loopTime;
const int pin_A = 7;
const int pin_B = 6;
unsigned char encoder_A;
unsigned char encoder_B;
unsigned char encoder_A_prev=0;
// declare pin 9 to be an output:
pinMode(9, OUTPUT);
pinMode(pin_A, INPUT);
pinMode(pin_B, INPUT);
currentTime = millis();
loopTime = currentTime;
// get the current elapsed time
if(currentTime >= (loopTime + 2.5)){
// 5ms since last check of encoder = 200Hz
encoder_A = digitalRead(pin_A); // Read encoder pins
encoder_B = digitalRead(pin_B);
if((!encoder_A) && (encoder_A_prev)){
// A has gone from high to low
if(encoder_B) {
// B is high so clockwise
// increase the brightness, dont go over 255
if(brightness + fadeAmount <= 255) brightness += fadeAmount;
else {
// B is low so counter-clockwise
// decrease the brightness, dont go below 0
if(brightness - fadeAmount >= 0) brightness -= fadeAmount;
encoder_A_prev = encoder_A; // Store value of A for next time
// set the brightness of pin 9:
analogWrite(9, brightness);
loopTime = currentTime; // Updates loopTime
// Other processing can be done here
DAC Sketch
// MCPDAC relies on SPI.
#include <SPI.h>
#include <MCPDAC.h>
// CS on pin 10, no LDAC pin (tie it to ground).
MCPDAC.begin(10);
// Set the gain to "HIGH" mode - 0 to 4096mV.
MCPDAC.setGain(CHANNEL_A,GAIN_HIGH);
// Do not shut down channel A, but shut down channel B.
MCPDAC.shutdown(CHANNEL_A,false);
MCPDAC.shutdown(CHANNEL_B,true);
static unsigned int volts;
// Set the voltage of channel A.
MCPDAC.setVoltage(CHANNEL_A,volts&0x0fff);
// Increase the voltage in steps of 100mV.
volts+=100;
Given the two sketches worked for you and also given that the forum system didn't hide characters because you didn't use code tags, this should be what you're looking for:
#include <SPI.h>
#include <MCPDAC.h>
MCPDAC.begin(10);
if(encoder_B) {
// increase the brightness, dont go over 4095
if(brightness + fadeAmount <= 0x0FFF) brightness += fadeAmount;
else {
MCPDAC.setVoltage(CHANNEL_A,brightness&0x0fff);
whoops forgot the code tag changed now :* Thanks so much for doing that mate but unfortunately it doesnt seem to be working ive double checked with just the two original sketches and they seemed fine just wanted to double check my wiring any ideas :~
thats correct the two sketches work fine by themselves
Rotory encoder -i was able to output a pwm signal which i filtered which gave us a 0 -5v and the encoder worked fine both ways
DAC uploaded sketch worked fine which i checked on the scope which gave a ramped waveform
Try this one and check the PWM output on pin 9. Don't forget you have to turn 16 times as much to have the same effect because you wanted to have more resolution.
#include <SPI.h>
#include <MCPDAC.h>
MCPDAC.begin(10);
pinMode(9, OUTPUT);
if(encoder_B) {
else {
analogWrite(9, brightness >> 4);
