RS232 Arduino Shield
Hi there,
I am trying to connect a device with Rs232 output to Arduino. I bought a rs232 Arduino shield but although I tried several time the software serial with different pin (2-7)to connect them I couldn't receive any thing from device I know the device is working well because with other connector (rs232 to usb) I can see the data in computer.
softwareSerial Myserial (rx, tx)
Any advice?
Regards,
Ali
Which RS232 shield?
If that's all your code I think I see the problem.
If not why did you post it?
With regards to the shield (rs232 Arduino shield).
Below is the code which I used.
#include <SoftwareSerial.h>                           //we have to include the SoftwareSerial library, or else we can't use it
#define rx 2                                          //define what pin rx is going to be
#define tx 3                                          //define what pin tx is going to be
SoftwareSerial myserial(rx, tx);                      //define how the soft serial port is going to work
String inputstring = "";                              //a string to hold incoming data from the PC
String sensorstring = "";                             //a string to hold the data from the Atlas Scientific product
boolean input_string_complete = false;                //have we received all the data from the PC
boolean sensor_string_complete = false;               //have we received all the data from the Atlas Scientific product
float pH;                                             //used to hold a floating point number that is the pH
void setup() {                                        //set up the hardware
  Serial.begin(9600);                                 //set baud rate for the hardware serial port_0 to 9600
  myserial.begin(9600);                               //set baud rate for the software serial port to 9600
  inputstring.reserve(10);                            //set aside some bytes for receiving data from the PC
  sensorstring.reserve(30);                           //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() {                                  //if the hardware serial port_0 receives a char
  inputstring = Serial.readStringUntil(13);           //read the string until we see a <CR>
  input_string_complete = true;                       //set the flag used to tell if we have received a completed string from the PC
void loop() {                                         //here we go...
  if (input_string_complete) {                        //if a string from the PC has been received in its entirety
    myserial.print(inputstring);                      //send that string to the Atlas Scientific product
    myserial.print('\r');                             //add a <CR> to the end of the string
    inputstring = "";                                 //clear the string
    input_string_complete = false;                    //reset the flag used to tell if we have received a completed string from the PC
  if (myserial.available() > 0) {                     //if we see that the Atlas Scientific product has sent a character
    char inchar = (char)myserial.read();              //get the char we just received
    sensorstring += inchar;                           //add the char to the var called sensorstring
    if (inchar == '\r') {                             //if the incoming character is a <CR>
      sensor_string_complete = true;                  //set the flag
  if (sensor_string_complete == true) {               //if a string from the Atlas Scientific product has been received in its entirety
    Serial.println(sensorstring);                     //send that string to the PC's serial monitor
    if (isdigit(sensorstring[0])) {                   //if the first character in the string is a digit
      pH = sensorstring.toFloat();                    //convert the string to a floating point number so it can be evaluated by the Arduino
      if (pH >= 7.0) {                                //if the pH is greater than or equal to 7.0
        Serial.println("high");                       //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
      if (pH <= 6.999) {                              //if the pH is less than or equal to 6.999
        Serial.println("low");                        //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
    sensorstring = "";                                //clear the string
    sensor_string_complete = false;                   //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
ieee488:
Which RS232 shield?
Welcome to the forum.
Which RS232 shield?
  • Supplier.
  • Model Number.
  • Picture.
  • Library (if any).
Sorry, but what you are telling us is like, you have a car, tell me how to drive it?
You could have a Model-T, 57 Chevy, Tesla, Prius, or a Stanley Steamer, each you drive differently.
Thanks.. Tom. :slight_smile:
Attached is the rs232 shield which I used
Below is the link to rs232 shield which I used.
Thanks
OK so what links have you made on the board?
And which connections on the board?
Your board is advertised on that site under
Home>PRODUCTS>Kits, Science & Learning>Science /Lab Equipment>Models/Puzzles
and it looks like it will be one :smiley:
Did it come with any documentation? If so, read it and set it up. If not, try to understand what all jumper fields are for. There must be a way t configure it for pin 0/1 or for other pins for software serial. A multimeter can be useful to figure it all out.
Hi
As you can see in the code I have configured the softwareSerial with pin 2,3 (rx, Tx) and the jumper set to pin 2,3 but I couldn't received any data from device output.
Thanks
Ali
Start simple. Communicate with a computer with RS232 port (or USB/RS232 adapter). Send some data from an Arduino sketch and use something like Putty or Realterm and see what comes in. Once you have tat working (see thought 1 below as well), write a sketch that reads from the serial port and e.g. echoes it.
Once that's working, you should be ready to connect it to the device (you might have to swap pin 2 nd 3 again).
Other thoughts
1)
You might also have pins 2 and 3 swapped.
2)
I assume you have tested you device against the computer?
3)
Any handshaking required by the device?
Thanks for your respond
As I said before, the device is working well with computer through rs232 to usb converter.
However I can't receive any data by rs232 Arduino shields.
Is there any way to connect the converter (rs232 to usb) to Arduino through usb?
Regards,
Ali
AlirezaRabieh:
Regards,
Ali
Ali, are you sure you're device is using RS-232? The comments in your code mention Atlas Scientific devices. They don't use RS-232, but UART. So, in case you'r "device" is an EZO circuit, you will not need that RS-232 shield. You can hook up those stamps directly to the pins of your Arduino.
Patrick
