Hi all, new guy here... I have an RS232 barcode scanner and I am trying to read its data from my arduino (I have the Wboard Pro, which is basically the same as the Mega with wifi). So I have connected the 5v and the GND pins and its powering on just fine and also connected the scanner's RX-TX pins to the TX-RX of the board respectively. How can I read the scanner's data? I have tried to use the SoftwareSerial example but nothing comes on the monitor when I scan....
Hi Morgan, thanks for the reply. I am now trying to include the invert option in my code like that (I added the “true”… Am I doing it right? I don’t get anything back… Can it be a baud setting or is it incorrect voltage levels?
#include <SoftwareSerial.h>
SoftwareSerial barcode = SoftwareSerial(10, 8, true); // RX, TX (TX not used, but the constructor wants a number anyway)
Serial.println("Barcode Scanner Test!");
// Open the SoftwareSerial port of the barcode scanner
barcode.begin(9600);
if(barcode.available())
Serial.println("Read");
char data = barcode.read();
Serial.write(data);
So if this does not work do I have to get something like this?
