the code
byte deviceId = 'A';
byte inpPins[5] = {14,15,16,17,7};
//byte outPins[5] = {13,12,11,10,9};
byte outPins[5] = {9,10,11,12,13};
byte ledPins[5] = {6,5,4,3,2};
byte currState[5]= {0,0,0,0,0};
byte lastState[5]= {0,0,0,0,0};
int enablePin = 8; // ebanble pin for slave
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
String inputString2 = ""; // a string to hold incoming data
boolean stringComplete2 = false; // whether the string is complete
byte outPinStatusIndex = 0;
byte outGoDownPinIndex = 1;
byte outGoUpPinIndex = 2;
byte inpLimitDownPinIndex = 0;
byte inpLimitUpPinIndex = 1;
bool goDown = false;
bool goUp = false;
char lastAct= 'x';//u==up d == down
for(int i=0; i < 5; i++){
pinMode(inpPins[i],INPUT);
pinMode(outPins[i],OUTPUT);
pinMode(ledPins[i],OUTPUT);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, LOW);//reciver
delay(4000);
//digitalWrite(enablePin, HIGH);//sender
// delay(1000);
// Serial.println("readdy");
//delay(1000);
// delay(1000);
if(goDown){
// if(lastAct!='d'){
// lastAct='d';
digitalWrite(outPins[1],HIGH);
if(digitalRead(inpPins[inpLimitDownPinIndex])){
goDown=false;
stopMove();
// }else{
// goDown=false;
// stopMove();
}else
if(goUp){// && lastAct!='u'){
// if(lastAct!='u'){
// lastAct='u';
digitalWrite(outPins[1],LOW);
if(digitalRead(inpPins[inpLimitUpPinIndex])){
goUp=false;
stopMove();
// }else{
// goUp=false;
// stopMove();
}else{
digitalWrite(outPins[outPinStatusIndex],LOW);
delay(20);
digitalWrite(outPins[outPinStatusIndex],HIGH);
delay(20);
if (stringComplete) {
delay(20);
//Serial.println(inputString);
if (inputString.charAt(2) == deviceId) {
if(inputString.charAt(3) == '1'){//go down
//Serial.println("go DOWN");
//delay(10);
//digitalWrite(enablePin, LOW);//reciver
digitalWrite(outPins[outGoDownPinIndex],HIGH);
digitalWrite(outPins[outGoUpPinIndex],LOW);
goDown=true;
goUp=false;
}else
if(inputString.charAt(3) == '2'){//go up
// delay(10);
//Serial.println("go UP");
//delay(10);
digitalWrite(outPins[outGoDownPinIndex],LOW);
digitalWrite(outPins[outGoUpPinIndex],HIGH);
goDown=false;
goUp=true;
}else
if(inputString.charAt(3) == '0'){//STAY
stopMove();
goDown=false;
goUp=false;
inputString = "";
}//main loop
void stopMove(){
//Serial.println("STOP");
void serialEvent() {/* SerialEvent occurs whenever a new data comes in the hardware serial RX. This routine is run between each time loop() runs, so using delay inside loop can delay response. Multiple bytes of data may be available. */
while (Serial.available()) {
char inChar = (char)Serial.read(); // get the new byte:
inputString += inChar; // add it to the inputString:
if (inChar == '\n') { // if the incoming character is a newline, set a flag // so the main loop can do something about it:
if (inputString.charAt(0) == 'X' && inputString.charAt(1) == 'X' ){
stringComplete = true;
}//if
}//if
}//while
}//serial event
The code is simple..
listen to com port and when
XXA1 (go up until the xternal signal is high)
XXA2 (go down until external signal is high)
XXA0 (turn of all outputs)
if nothing is going on the LED is blinking
pcb.pdf (200 KB)
