RTC DS1307 With Arduino Without RTC library
Hello ,
When I connected RTC DS1307 with Arduino by this code :
#include<Wire.h>
Wire.begin();
Wire.beginTransmission(0x68);
 Wire.write("START");
 Wire.endTransmission(true);
  Wire.requestFrom(0x68,7 );
  while(Wire.available()) {
int c = Wire.read();
Serial.println(c-200);
delay(2000);
I get those various values in Serial Monitor
255
253
255
251
207
234
239
what should i do if i wanted to show SECONDS,MINUTES,HOURS,DAY,DATE,MONTH and YEAR ?
Shouldn't you be writing the address of the register that you want to start reading from, probably zero, instead of the word "START" ?
Kiroloes:
Chuck out that junk and use something that works. You might just check that wiring as well. If the module supplier says you must use those resistors, then fine, but I have never seen anything like that.
