Im using a DS3231 and sometimes when i hit the reset button on the MCU it will stop communicating with the RTC module. the only way to make it start working again is to power cycle the RTC module or short the SDA SCL pins. why is this happening?
Can you please provide your code; the easiest is probably to use edit → copy for forum in the IDE and next paste it here. It will take care of the formatting and it will be easy for us to copy.
Can you please provide details of the board that you’re using.
And provide a schematic diagram (including all power connections); photo of handrawn one is fine.
Im using ESP8266 as MCU, i found that if i manually digitalWrite the SDA and SCL pins low in setup then 75 percent of the time theres no problem. There are pullup resistor onboard the DS3231. when the RTC module fails the epoch always == 94668480. so i put a check in the setup. if epoch==946684800 then ESP.reboot(). this is not ideal but it works. if i remove the digitalWrites then it will just endlessly reboot.
#include <Wire.h> //I2C library
#include <RtcDS3231.h> //RTC library
unsigned long now = 0;
unsigned long now2 = 0;
RtcDS3231<TwoWire> rtc(Wire);
Serial.begin(115200); //Starts serial connection
Serial.println("rebooting");
rtc.Begin(); //Starts I2C
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
RtcDateTime currentTime = RtcDateTime(16, 05, 18, 21, 20, 0); //define date and time object
rtc.SetDateTime(currentTime); //configure the RTC with object
RtcDateTime epoch32 = rtc.GetDateTime();
unsigned long epochTime = epoch32.Epoch32Time();
if (epochTime == 946684800) {
ESP.restart();
void handleGetTime() {
RtcDateTime currentTime = rtc.GetDateTime(); //get the time from the RTC
char str[20]; //declare a string as an array of chars
sprintf(str, "%d/%d/%d %d:%d:%d", //%d allows to print an integer to the string
currentTime.Year(), //get year method
currentTime.Month(), //get month method
currentTime.Day(), //get day method
currentTime.Hour(), //get hour method
currentTime.Minute(), //get minute method
currentTime.Second() //get second method
Serial.println(str); //print the string to the serial port
ESP.restart();
if (epochTime - now2 > 1) {
Serial.println("hello");
now2 = epochTime;
if (millis() - now > 1000) {
Serial.println(epochTime);
// handleGetTime();
now = millis();
Not sure if it will work on a 3.3 volt output, but the DS3231 can be powered by an output pin, making it easy to power cycle the RTC.
