I'm working on a datalogger with Arduino and everything was working fine until I resolve to write a timestamp in each line on my data file. After this the SD stopped to work, but if I try to run the examples code of each libraries separated , SD or RTC, it works fine.
The problem is when I try to run SD and RTC libraries together.
I tried others SD libraries instead of SD.h, now I'm using SdFat.h and other RTC libraries but the same problem.
This is the examples codes of SdFat.h and DS1307.h libraries merged.
If I comment out the line "myFile.print(RTC.get(DS1307_YR,false), DEC);" the SD card stops to work.
Any ideas?
Thanks
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h> // written by mattt on the Arduino forum and modified by D. Sjunnesson
#include <SdFat.h>
SdFat sd;
SdFile myFile;
const int chipSelect = 4;
pinMode(3, OUTPUT);
// Initialize SdFat or print a detailed error message and halt
// Use half speed like the native library.
// change to SPI_FULL_SPEED for more performance.
// re-open the file for reading:
// read from the file until there's nothing else in it:
int data;
digitalWrite(3, HIGH);
if (!sd.init(SPI_HALF_SPEED, chipSelect)) sd.initErrorHalt();
// open the file for write at end like the Native SD library
if (!myFile.open("test.txt", O_RDWR | O_CREAT | O_AT_END)) {
sd.errorHalt("opening test.txt for write failed");
// if the file opened okay, write to it:
myFile.println("testing 1, 2, 3.");
// myFile.print(RTC.get(DS1307_YR,false), DEC);
myFile.print('/');
// close the file:
myFile.close();
digitalWrite(3, LOW);
delay (1000);
sd.init() should be performed ONCE, not every pass through loop.
Separate the code into reasonable pieces. What does RTC.get() return, if anything? What does "the SD card stops to work" mean? Does the SD card then stop working? Or does it start working?
int data;
So, where is the code to implement the comments? What is data for?
Yes, you are right. Originally sd.init() is in setup() on the sdfat.h examples, but I made some tests and forgot to move it back.
"Does the SD card then stop working"
I removed some lines from original example code that is not important to reproduce the problem and forgot the comments and data. This is not important.
Have you run out of code or ram space? The RTC library uses the I2C bus which doesn't conflict with the SDcard on the SPI bus, I can only think that you've got too much code or ram usage when using both libraries.
Yes, SD library takes a lot of room, the 328 is pretty much required - unless you can find a smaller SD library that does enough for you and allows everything to fit on a 168.
I have a problem with my RTC mod isn't the famous ref DS1307 which is well documented but RTC PCF8563 and i would like to get the hour in a file.txt on my SD card!!
I have a code of RTC which is working and i was trying to see how to write and erase data on SD card but i don't know how can i handling this problem!!
Depending on how you open the file, erasing may not be necessary. There are examples in the SD library. I fail to see what the problem is. (And I fail to see your code.)
